Question about Spinmaster Air Hogs RC Reflex Micro Helicopter
Lost clip under choper holding the shaft rotor doesn't spin?
  • LuiTutin May 11, 2010
    If this is a Reflex with opposing rotors there is no "clip" . I had the same problem and took the darn thing apart. Gear for the upper rotor is not glued or splined to the shaft (not sure how the darn thing is really attached) so I tried to glue the gear inplace. Both rotors spin at the same rate and lift the craft but the trim wheel does not compensate so the fuselage spins uncontrolably. Figured lubricating the gear box with lithium/graphite might reduce friction but still no luck. If you figure it out please post the solution. If you take yours apart use an Exacto knife to split the body, (be careful cause the tail section has the antenna wire running along the inside) and dont forget to remove the screws that retain the plate that houses the on/off switch and chargeing port.
    Problem Solver:
  • 7 Answers
Mar 10, 2010- Don't know if you ever solved this issue but if the problem is still there and you feel adventerous you can try to fix it.If the top rotor and shaft came loose, (either it pulls out or if you turn the upper rotor and it does not engage and turn the lower one at the same rate) I used an exacto knife to cut along the seam of mine,(you have to be careful especially in the tail section as the antenna wire runs along its length). You will have to caerfully bend up the directional fans to remove each side of the body once separated. Use a small jewelers screwdriver to open the motor housing - there is a screw on the vertical rotor housing section right behind the circut board that you will have to get to by going in on an angle - being careful not to lose the small washer on the shaft above the lower gear. Remove the upper rotor and shaft and the gear and washer. Clean all with rubbing alcohol. Now here is the hard part - place the gear back into the lower half of the motor housing, insert the upper rotor shaft into the gear until it bottoms out and mark the shaft at the top of the gear, (a dab of liquid white-out used for typing errors works well becuse it dries fast). Once dry remove the shaft and pull the gear off of it. Measure from the bottom of the shaft to the white mark and write it down - you can use a piece of paper as a guide by lining up one edge with the bottom of the shaft and placing a mark at the spot of the white out if using a ruler is too difficult to read. clean any grease off of the shaft and inside of the gear. Since the shaft is carbon fiber and the gear is polyethylene plastic not many glues work well. I used "J-B weld" a two part epoxy that is tough as nails and holds up well. place a mark on the paper guide approximately 1/64th of an inch above the original mark. This is how far you will have to place the gear from the end of the shaft, (this allows for less friction and keeps the lower gear from rubbing on the bottom of the gearbox...VERY IMPORTANT!!! insert the upper rotor shaft into the shaft housing in the top part of the gear box and place the small washer on it. Use the paper guide you made and put a small dab of white-out on the shaft using the new mark a your point of reference, (rember it's 1/64" above the original mark). Mix up a tiny amount of JB weld and put a thin coat on the shaft just below the mark. Slide the gear onto the shaft up to the mark and set aside overnight to harden. Next day reassemble the gearbox, (if you placed the gear too high up on the shaft the two halves of the gear box will not come together. DO NOT force it. use a file to take alittle off of the end of the shaft until the gearbox seats together tightly and reinstall assembly into the heli. I would tape the two halves together with scotch tape until you know you got it right. Try the heli using the trim wheel to stop rotation. If better but still not right check the flex on the rotor blades as it seems if used alot they get soft and flex too much which makes it hard to adjust. If they do flex alot try coating each with a THIN layer of JB weld to stiffen them up. This is a very delicate procedure as if you put too much on the balance will be shot. Seems like alot of messing around for a $40.00 toy but I enjoyed the challenge and it is rewarding to solve a problem and win.
Posted on Mar 10, 2010
WASHING MACHINE
THIS symptom means but ONE thing. The drum clutch is burnt and slipping or said clutch is worn out. I just replaced the clutch and hub unit in my washer, original was burnt and slipping because of past overloading. The ole lady said "NOT ME, I NEVER OVERLOAD IT". Well, it works fine now. If yours is a Kenmore washer and drives right off the transmission, you have to remove the outer shell, remove the cap on agitator, then the 7/16 head bolt in the center that holds the agitator to the shaft, turn the unit on it's back, this after unhooking electric and hoses from back, then remove the pump by popping the clips off, remove the motor by removing the 2 screws in clips and popping the clips off and pull motor strait off, unhook the electric cable that powers the motor and pop same cable off the retainer that keeps it on the transmission, remove the 3 1/2 inch head bolts that hold the transmission to the standoffs, pull the transmission completely out of the washer and you'll see the clutch on the top around the shaft. under the concave washer, Remove the push-clip from shaft at clutch hub. Remove the spring clip that holds clutch to trans. Slide the clutch hub up and off the shaft. Place the NEW clutch hub on the trans and put it all back together. You'll find your washer works perfectly now. Plenty of spinning speed.
Aug 31, 2014 | Washing Machines
Replacing impeller
Remove the back cover of the motor to expose the plastic fan. Find the c clip that holds it on the motor shaft. Remove the nut that is on the front side of the impeller. I used a vise grips to hold the shaft from spinning on the side where the fan was. A small 2 or 3 arm puller hooked under the front shoulder of the impeller and that is all you need to do.
Feb 26, 2013 | Hobart AM14-253 Free-standing Dishwasher
The tail rotor wont spin
It appears that the tail rotor holds the horizontal stability when going backwards. i.e. only works when command is backward.
If the tail rotor does not spin then try lubricating the shaft with some talcum powder. To test whether it working blow down on to the rotor and it should spin rapidly. The talcum powder worked for me.
May 05, 2011 | Spinmaster Air Hogs Yellow Jackal R/C...
How do I remove the rear axle
The rear axle shaft?? Or the entire axle? I'm going to go with the axle shaft. Secure the vehicle. Loosen the lug nuts. Jack it up. Take the wheel and tire off. Remove the caliper and/or bracket. Remove the rotor. Place a pan under the rear differential cover. Remove the rear differential cover. Spin the axle shaft to reveal the center pin. Locate the 8mm-5/16 bolt that holds the center pin in place. Remove that bolt. Slide the center pin out, BUT DON'T TURN THE AXLE SHAFTS WHILE ITS OUT! Push the axle shaft in from the outer portion (where the wheel goes). A "C" clip will fall out inside of the differential. Pull the axle shaft out. Slide the center pin back in. Replace the 8mm-5/16 locking bolt and spin it a few times to keep everything in place.
Feb 23, 2011 | 2000 GMC Jimmy
The tail rotor will not work. The tiny motor is not working so it does not spin the rotor. What can I do???
doubld blade rotor there is no need for a rear/tail rotor, on the remote are 2 buttons they will control Left/Right spin , adjust so that it does not spin around
Feb 05, 2011 | JCPenney Gyropter RC Helicopter
The top rotor of my syma S107 is not working and the motor is making a different sound. What should I do?
This is a counter rotational craft and thus there should be two electric engines turning one rotor each. The top rotor is probably connected to the lover gear, and thus this is where you should start looking.
When you turn your top rotor, do any of the gears move? Try holding the gear while turning the rotor also, if the rotor is spin able while holding the gear then your rotor shaft is damaged and the entire rotor should be replaced if possible.
Also, try turning both rotors and see if one spins heavier than the other. This should
also indicate damage to the construction, or the engine.
If everything is looking all right, and all the gears turns all the way to the engine, and everything looks tight, then it is a great possibility your engine is fried.
Many of the sets have easily changeable rotors and rotor shafts, and some also have easily changeable gears. However, most cheap crafts like this do not have easily changeable engines. I do not know this model, so this you have to investigate. Now, it is possible to do engine shifts by yourself even if the manufacturer does not provide spare parts, but I
Dec 23, 2010 | SYMA Toys industrial New Syma S107 Mini...
How do i remove the rear axle shalfs from my 2000 chevy blazer s10
you have to remove the cover then spin the carrier assembly by spinning drive shaft un till you see a mall bolt that will hold the pin in that runs through the center of the carrier remove bolt remove pin push axle shaft in so that c clip can fall out with c clip out remove shaft when re installing push axle in all the way put c clip in and pull axle shaft out word and reinstall pin bolt and cover.
Dec 15, 2010 | Chevrolet Blazer Cars & Trucks
No spinning on any of my spin cycles
If this is the Roper top load washer, you probably need a new motor coupler. Always unplug your appliance before repairing. There are two screws located on the front corners of the control panel. Remove these screws and tilt the control panel back. There are two clips holding the cabnet to the rear panel. Remove the two clips and remove the wiring harness with the 3 wires going to the cabnet. Tilt the cabnet forward and remove. Remove the two clips holding the pump in place and remove the pump from the motor. Remove the two screws hold the two clips holding the motor on. Remove the clips and the motor. Using a large screw driver remove the white plastic coupling from the rear motor shaft and the other half on the transmission shaft. Tap the new coulpler on with the end of a 3/8 socket extention so that the face of the plastic coupler is flush with the shaft. Insert the rubber part of the coupler in between the two halv'es of the coupler and reinstall the motor.
Reinstall the pump and put the cabnet back on. Reinstall the clips holding the cabnet on and the wiring harness. Tilt the control panel back in place and replace the two screws. Plug your maching back in and test. I hope this helps.
Jan 21, 2010 | Roper Washing Machines
Heli wont go up very much and turns to the left
If thi is a Reflex with two opposing rotors and two directional fans then use the "trim wheel" on the top of the rotor assembly to counteract the spin. If you crashed it often enough the shaft for the top rotor may have come loose. I'm not sure how this actually works with the trim wheel but mine crashed a bit and the shaft came out. I re-inserted it and it worked OK for a while but eventually the gear inside stoppped grabbing the shaft and the top rotor would not spin. I took it apart and tried gluing the gear to the shaft and that got the rotor to spin at the same rate as the lower rotor but I could not trim to get rid of the spin on the body. I would advise not buying the Reflex becuse it does not hold up very well. I went out and purchased a Sharpshooter which is easier to fly and seems more durable
Jan 12, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Removing distributor rotor
there is a little screw holding rotor to shaft rotate engine to spin rotor screw is on front of rotor on shaft
Dec 27, 2008 | 2000 Honda Civic
Spinmaster Air Hogs RC Reflex Micro Helicopter Logo
163 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
