Question about Nokia N70 Cellular Phone
N 70 charging problem
Hello sir i have n 70 charging does not show i have changed retu tahov ics and changed components also but it does not show charging pls help me thank u
  • 1 more comment
  • kizer pasha Feb 28, 2008
    sir the problem in n 70 is it does not respond when we plug it for charging it does not showing at all after changing ics pls help me to slove this problem thank u
  • Anonymous Apr 16, 2008
    I tried to remove the battery & fix back, but still won't work for the charging. What is the problem? Pls helpme.....tks
    pls e-mail me if possible....
  • arunsingh767 Dec 07, 2008
    please help me
Put out battery first than fix it again and restart your phone and than recharge ur cell.
Posted on Feb 22, 2008
Samsung gt e3213k charging problem.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 07, 2012 | Samsung Cell Phones
Nokia 3110 fall in to watter and dead
1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 4..remove this coil mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery.... 5..remove this coil mark in (5)..if u want to check the light ic is short.... 6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic..... 7..at end remove retu and tahvo ic .. all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .3500short.jpg
Dec 06, 2011 | Nokia 3110 Cellular Phone
Spice m-4580 invalid charger problem.
SIR. 4580 MOBIL ME CHARGING INVELID LIKHA AA RAHA HAIN
Sep 05, 2011 | Health & Beauty
The component no is IC 101. i want to no what is the number of that ic
Hello sir... the number of the IC is written on top of it. If you can read the words and numbers written on it, call a child to read it for you.
Dec 04, 2010 | Televison & Video
Hi. when i plug charger phone typing NOT CHARGING. the problem after change retu. retu changhed 3
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And ifcharger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 21, 2010 | Nokia 6288 Cellular Phone
My nokia 6280 is not keeping gharge and is refusing to charge
1-Try another trusted genuine battery.
2- Try another trusted genuine charger.
3- If RETU IC is not under-filled try yo reflow it, if not works then replace it.
4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) .
maybe ur bsi line short to ground!!
try to remove the resistor in bsi line....
Mar 21, 2009 | Nokia 6280 Cellular Phone
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
Nokia N73 Music voice problem
dear sir ,
pls upgrade the software&change the MIC of the phone ,if not solved than change the IC( retu).
Jan 20, 2008 | Nokia N73 Cellular Phone
Loudspeaker - hardware
dear sir,
u go to the NOKIA CARE CENTRE, & ask him to upgrade the software of the mobile phone.
&if not solved than change the ihf ringer.if not than change RETU ic.
Jan 19, 2008 | Nokia N73 Cellular Phone
Nokia N70 bluetooth problem
your phones blutooth IC is damaged you have to change bluetooth IC .
Dec 11, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
113 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
