Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
I took the two big black plastic spring loaded screws out and put them back in, now it's not working...
  • 235 Answers
Hi, ANNEQUESTRIA, I hate it when that happens. Those ‘two big black plastic spring loaded screws’ are your mixer’s electric motor brushes. The slotted black threaded plastic parts are just the Brush Holder Caps and are protective covers to the brush holder assemblies. They allow access to the brushes when they need to be replaced without have to take the whole mixer head apart. What prompted you to remove them?
From what’s been done already, still I suspect that one or both of the brushes is (are) not seated properly.
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your KSM90P mixer falls within this manual), and select the last file KSM90PSWW0.pdf (354.08 KB) listed under Parts List (16) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Posted on Feb 09, 2010
  • 130 Answers
The burshes can only be inserted one way. if they are inserted in any other orientation the brush housing will stop them from even touching the armature's commutatir. they may look like they went in however measure the amount of spring sticking out in one orientation then rotate the brush 90 degrees and stick it back in the hole. in one and only one position will the spring go further into the hole. that is the correct position. you see, there is a flat on one corner of the brush that must line up with a brass tang which will hit all three other corners preventing the brush from entering the brush holder completely.
Before inserting the brushes make sure there is no burned flour on the curved face which contacts the commutator. very carefully scrape the curvature until you are sure there is no contamination there.
Posted on Mar 30, 2010
KitchenaidKsm6573CER1 the shear pin retaining fell out
If you are referring to the pin that holds the stand-lift lever to the stand-lift mechanism, then you'll have to remove the Motor Housing, remove the motor and the three screws below it. Then you'll want to seperate the Column from the Base by removing the three screws at the bottom of the Base. You can then access the lift assembly and all you need to do is reassemble the lever and the plastic hitch (forgot the specific name) to the bar with the spring and nut on the bottom, then secure it in place with your shear pin. (The pin may have to be re-bent into shape with needle-nose pliers, and I also advise putting "Locktite" onto the threads of the six screw that are used to secure the base and column to the lower gearcase.)
I hope this helps!
Nov 23, 2014 | KitchenAid 6000 HD STAND MIXER 6 qt BIG...
Wont turn on
Try checking the brushes located on the side of the mixer ,theres one on each side under a black plastic screw make sure you remember how you took them out,put them back same place.
Oct 23, 2012 | KitchenAid K5SS Heavy Duty Commercial...
The bushing in my kitchenaid KSM 90 cracked in half, how do I get it out of the hole?
Try tipping the mixer on it's side. the brush holder is a solid brass piece that goes all the way to the armature. You might also try fishing with a hat needle or a dental pick. If it truly is stuck in there and will not come out you are into a complete motor tear down to remove the brush holder to get at the culprit..
Sep 02, 2012 | KitchenAid Food Mixers
Mixer won't turn on. I had the pin problem everyone describes. Finally was able to get the pin back in with some serious hammering of the pin and then tightened the set screw on the bottom. Fabulous!...
They are the brush springs. The brushes get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
Jan 29, 2010 | Food Mixers
My kitchen aid mixer would not turn off. I pulled
you have lost the internal spring on the slide arm. a common problem but now the speed adjuster has been let go in the back of the motor. Best return to service centre as requires complete dismantle to repair, sorry.
Sep 13, 2009 | Food Mixers
Springs on side under black screw, came out
Or, more helpfully, take them back out.  Look in the hole, and you will notice that when you look through, the hole turns square. At the end the square, there is a little tab / square in one corner.  It is generally *not* the same on both sides. You'll notice that the end of the piece you took out (the part that looks like a magnet) has one corner cut off -- so it's a rectangular box with one of the corners gone.  Line up the missing corner of the piece you took out with the corner that has the little tab -- this allows the piece to get past the tab and be fully inserted.  Reminder: check both sides, because they're not the same. And now, more helpfully, if you're curious, check out flea markets and get a broken Kitchenaid to take apart for $20 or so. Don't mess with your nice one. : )
Apr 24, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Mixer stopped working after I took the black screws on the side out. Thought that I put it back in right with the springs. Maybe I didn't. What could have happened? Thanks Nancy
The brushes must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Classic K45SS STOPPED RUNNING
I have the same problem now what did you do to fix it?
Jul 26, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 gear stripped?
I just ran into this problem when the PLASTIC worm gear broke and then the mixer would not power on after I replaced the gear. The problem was due to the was I tried to dissasemble the mixer. I removed the two plastic screws near the top center of the mixer when attempting to disassemble. These do not have anything to do with the assembly it turns out the attached square pieces (attached to these screws by springs) must be in the proper orientation to run. I put them in the way it showed in a diagram but it did not work until I tried all four different combinations that they could be rotated. Two of the rotations on the square could be eliminated by closely looking at the end where it contacts the shaft. The round shaft marking will be evident on the square inserts. I'mnotsure how to better describe them, but the are attached by springs to the plastic screws on both sides of the top of the mixer.
May 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
387 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
