Question about Acer AL1714 17" LCD Monitor
Monitor off centre when booting up into dos
No clue as to why this is happening but for some reason when starting up my PC into Windows (which displays fine) or booting up into DOS, the screen would is off centre (can't see anything on either the left side of the screen or the top of the screen. So I'm wondering if any of you experts have any idea as to what may be the problem.
    Scholar:
  • 26 Answers
The monitor likely auto-synced off centered on that resolution because it couldn't find the edges of the black screen.
Try to figure out what resolution the DOS screen is using and then set windows to that resolution and then proceed to center the screen using the monitor's menu.
You can now switch back to the resolution of your liking.
On next reboot, the monitor should keep the settings for that resolution.
Posted on Feb 22, 2008
Cursor not moving, it is standstill on monitor , how to resolve ?
boot up in Safe mode using a function "F" key when booting up cold... (not a Restart). In "Start", type in "cmd", and then "chkdsk/f" without the quotation marks in the new window with the cursor as it is. The DOS (backdoor) program will repair your Operating System errors for you automatically, please be patient. If that doesn't fix you problem, please check my previous post on Gateway that doesn't boot.
Feb 16, 2015 | Gateway NV4402u Notebook
Pc powers up then shuts down
The processsor needs to be changed
Aug 25, 2014 | HP Pavilion a6110n PC Desktop
Far cry 2 keeps crashing to blackscreen
When does this crashing or black screen happen? During the boot up process or while you have windows booted all the way up?
If the computer is booting up all the way except the screen is black try the steps below.
Either your monitor or video card inside the computer is bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without any problems then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If the computer is not booting up all the way then try the steps below.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 07, 2012 | Computers & Internet
My laptop wont load the screen on boot up it is all black i tried hooking up a external monitor to it and it wont find the monitor or if it does the screen is still black.
Sometimes it happens that you start the computer and get black screen having this message, "NTLDR is missing press Ctrl +ALT +DEL to restart". This mostly happens when the virus infects your computer, because most of the viruses attach themselves to the NTLDR files. This can also happen due to power failures, problem in master boot sector, corrupt bios settings, or some other problem in the boot.ini file. These files play a very important role in rebooting the system and if there comes any problem or they get corrupted by some virus or for some other reason, then they do not allow the hard drive to boot. However, its not that much difficult to fix this error, as all you need is to get your installation cd and then need to follow some simple steps. This will definitely help you in fixing your boot loader to the working state.
*First, you need to get your installation cd and then place it in your hard drive and restart your system.
*After restarting the system, you will get message "Press any key to enter setup". So, follow this message and press any key, this will take you to the setup. However, there could be some different scenario as well depending on your bios setting. This is because of the fact that if you have not given priority to your hard drive then it would not boot in this way. For this, you need to change your boot device priority and its better that you set this priority to your CD Drive.
*Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with RegInOut Registry Cleaner and PC Optimizer. The Intel software partner program, RegInOut thoroughly clean your registry and helps to avoid Windows errors and crashes. If you place the registry protection in place it will give a great boost to the Windows internal functions.
To start a seventeen seconds download of this amazing program just go to this location and directly download the program from Intel Software Partners
Aug 31, 2010 | Computers & Internet
Pc is dead !!
you need window xp disc to boot from and install.You could borrow from a friend. you will also need the serial code.
Oct 05, 2008 | Computers & Internet
RESET BIOS COM
1. Boot up your PC with a DOS Boot Disk or WINDOWS boot disc
2. At the DOS PROMPT or WINDOWS DOS PROMPT clear the master boot record with this command.
"fdisk /mbr" without the quotes.
This will remove the boot sector virus
3. Reinstall windows
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
Acer TravelMate 330t
For some reason the "Shell" is not loading, try the following commands, see if they help.
WIN [enter] this should launch the normal explorer shell
Exit [enter] sometimes the system is set to boot to the dos interface, this will exit the dos shell and reload windows.
If neither command gets you to windows, then you may have a problem with your hard drive or windows install. Might be a good time for a newer system
Jun 30, 2008 | Acer TravelMate 2300 Notebook
Benq 19" monitor not working every time when computer started
Check your connections and make sure they are tight, and there are no bent pins. If everything seems ok, you might want to try plugging this monitor into a different computer or plug a different
monitor into yours to determine whether it's the monitor, the video card, or maybe the driver (doubtful on this as you state it seems to be bad somethimes on boot).
May 26, 2008 | BenQ Computers & Internet
Windows booting problem
hi sunnyh, when you start up the PC start pressing the F8 key every 2 seconds. A dos like window will load. At the bottom of the list choose, last known good configuration. (win might load the last good configuration) it's worth the try.
If your PC still does not load windows than repeat the above, this time choose, Disable automatic restart on system failure.
This also might allow windows to load (hopefully).
A system that starts going into this restart loop happens for many different reasons. Most common reason was a program that was last installed just before PC was restarted. Second most common reason for restart loop. Added new hardware, bios changes & windows boot files corrupted. If you did install a program, uninstall it. If you were in your bios & made changes, reset the bios. If you flashed the bios, go back to the old bios version. If you added new hardware replace with older hardware.
To fix Windows you may have to reinstall it. Do not run format or you will loose all your data. Even system restore CD's allow for a win reinstall without a format, however if the cd does not allow you to reinstall win unless you do a format. Than windows startup files are too screwed up & you'll have no choice but to format.
All you can do is try the above & cross your fingers.
Mike
Mar 22, 2008 | Gigabyte GA-8SR533 Motherboard
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Acer AL1714 17" LCD Monitor Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
