Question about Garmin GolfLogix GPS-8
How can I get the battery back cover with the belt clip adaptor wheel.
  • 63 Answers
I got a warranty replacement and they sent me one without the adaptor. I gave them a call, and they just shipped me a replacement, no questions asked. 877-977-0162. (don't call on a Monday. I made that mistake once, 15 minutes to talk to someone)
Posted on Jun 30, 2010
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
How to change an altanator on a 2004 kia optima
The KIA Optima uses a 12 volt charging system with an alternating generator and a frame-grounded starting battery. The alternator is a smaller unit with an internal voltage regulator. The bushings, windings and regulator may wear out and fail, requiring replacement. The average backyard mechanic can change the alternator in a KIA in about an hour.
Things You'll Need
1.Socket set
2.Floor jack
3.Lug wrench
4.Screwdrivers
5.Crowbar
Instructions:
1.Disconnect the battery's positive terminal bolt by turning it counterclockwise. Set it away from the terminal.
2.Jack up the Optima and remove the front passenger side wheel by turning the lug nuts counterclockwise using the lug wrench. Set the wheel and tire aside.
3.Remove or fold aside the wheel well cover by turning the small screws counterclockwise and gently pulling it from the retainer clips. This will give access to the engine.
4.Push on the belt tension pulley until the belt loosens, then pull the belt off of the alternator's pulley wheel. The belt can be left hanging in place.
5.Turn the alternator's bolts in a counterclockwise direction using the socket wrench. A smaller wrench head may be required for the tight space.
6.Pull the alternator free by wiggling it out of the mount.
7.Position the new alternator into the mount and secure the bolts that hold it in place.
8.Push on the belt tension pulley to give enough slack to wrap the belt around the alternator's pulley wheel.
9.Restore the wheel well cover by pushing it onto the clips and securing the screws.
10.Replace the wheel by tightening the lug nuts in a clockwise direction, alternating the pressure of opposing bolts. This sets the wheel better than tightening all of the nuts in a circle.
11.Lower the Optima onto the ground, and reconnect the battery.
Oct 24, 2011 | 2004 Kia Optima
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Midland LXT310 2-Way Radio
How do you change batteries
1. Remove the belt clip from the back of the radio. (Push spring clip at the top away from the radio, then slide the belt clip up and off).
2. Remove the battery cover by pressing down on the top center and sliding the cover down and off the radio.
Need the manual for your radios? You can download and print it, at no cost, here:
http://www.buytwowayradios.com/Products/Midland/manuals/LXT-110-manual.pdf
Oct 28, 2010 | Midland LXT80 Two Way Radio
How do you get the back off to change the batteries?
You didn't specify a model, byt nearly all of the current/recent Midland models are the same.
On the back of the radio, near the bottom, you should see a small tab with an indent above it. Place your finger tip or a coin in the indent and push the tab downward. Once that's done, just lift the battery cover from the bottom and remove it.
I hope this helps.
Bill B.
Aug 02, 2010 | Midland Radio Communications
Diagram for setting up belt on drum tenion
Replacing the Belt
  • Step 1 Put the dryer door-side down on the floor. This allows easier access to the back.
  • Step 2 Locate the center pivot suspending the dryer drum. If held by a clamp, removed any nuts or screws retaining the pivot axle.
  • Step 3 Move the pivot out of the bracket and slide the new belt inside the bracket.
  • Step 4 Replace the drum pivot in the bracket and reassemble the bracket.
    Looping the Belt
  • Step 1 Flip the dryer up so it is once again sitting upright.
  • Step 2 Locate the groove or wear mark the previous belt left in in the circumference of the drum.
  • Step 3 Wrap the belt around the drum in this groove or wear mark, with available slack at the bottom of the drum.
  • Step 4 Wrap the belt around the drive wheel located on the drive motor in the lower corner of the dryer.
  • Step 5 Insure the belt is snug but not biting the drive wheel. This indicates the proper size belt is installed.
    Reassembly
  • Step 1 Reattach any clips or wires to the back cover.
  • Step 2 Reattach the back cover using the six-sided sheet metal screws removed earlier.
  • Step 3 Reattach the top cover. Close tightly so clips secure the cover.
  • Step 4 Plug in the dryer and turn it on to test the belt repair.
  • Step 5 Reattach the dryer vent conduit
  • Feb 06, 2010 | GE Dryers
    The thing that pulls the cartridges back n forth has come off.
    hi yes it can be fixed, you need to take of a few covers and get it back down the carriage unit and put back on the belt.
    its not that bad of a job prob worst is working out how the covers come off.
    once they are off its a 5 minute job.
    Regards
    Canon Tech
    Apr 01, 2009 | Canon PIXMA iP1600 Printer
    Hoover Encore Supreme belt replacement
    Remove the bottom plate that covers the brush roll and remove the roller. The plate is removed by releasing two clips at the back corners of the plate on either side. Take the roller and install the belt around the pulley and put the other end of the belt through the access hole in the vacuum body. Replace the roller and turn it by haand to ensure that the belt is not pinched. Replace the bottom plate and turn the roller again (same reason).
    If you look at the area beside the rear wheel between the hood and the main body, you will see a clip incorporated into the hood. Take a screwdriver and pry it away from the main body. Do this on both sides. You will find a similar clip at the hood just beside the back corner of the plate in the front where the plate clips are located. Pry these as well and hood will come loose. Now you can turn the machine back on its' wheels and remove the hood. You will see the belt where it comes through the main body and you can grab it with a couple of fingers and stretch it onto the motor shaft. Replace the hood and the job is done.
    Mar 21, 2008 | Vacuums
    Garmin GolfLogix GPS-8 Logo
    27 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
