Question about Kodak EASYSHARE M340 Digital Camera
Some juice driped in from the top of the camara and now it won't start. I waited for it to dry and won't start. i have tried plugging it in to the computer but won't start at all. I have two batterys and 1 memory card 4GB i tried putting in a different battery and it still won't work....
  • kakima May 11, 2010
    Letting it dry may have been a mistake, if that only allowed whatever was in the juice to precipitate out. Did you rinse it before allowing it to dry? Did you first remove the battery?
    Genius:
  • Kodak Master
  • 1,099 Answers
Your camera is only supporting:
SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
Clean the camera and all the contacts with spirit, leave to dry open for at least 24 hours.
Good luck
Posted on Feb 09, 2010
Nintendo repairs
Unlikely after trying to power it on several times since it happened, as the juice is a salt that corrodes (and shorts out) sensitive internals. However if you really want to try, go find some 99% isopropyl alcohol (it CAN be found at drug stores, but might take a couple of stops, not much is kept in stock). If you can't find it, 90% will do, just has to dry longer and more likely to get water spots.
Pull the batteries and/or any power to the device until this is all done. Dunk the DS in the alcohol (if it doesn't work, won't matter either way since it's dead). Let it soak a long while, turning if you see bubbles stop, until you get more bubbles from any seams/ports to stop coming out. After soaking awhile, take it out, drain/shake it out very well, then dunk it again. Repeat several times, the idea is for the alcohol to dissolve any juice residue and related salts and drain them out. After 5 or 6 repeats of this, shake it out as best as you can, and let dry for a day or two (or on the floorboard (not dashboard or direct sun, it can warp/melt) of your car in the sun). Or get an electronics "dry bag" (designed for this purpose) to help dehydrate/dry out the DS. I'd still wait at least 2 days for good drying, shaking periodically to move around any wet alcohol spots internally. Once you are sure it's dry, then reinstall power and try it out. If it worked, it'll work, if not, it'll probably be doing the same thing it was before. Or it might do something else, but still not work, as things may have changed from the juice internally.
Dec 04, 2013 | Video Game Consoles & Games
It won't let me dry and says "loc"
Unplug and wait 3 minutes then re plug and start from beginning.
Jan 22, 2013 | Dryers
My 2009 turns over but won't start
try charging your battery or replacing it.. if the problem is not solve.. diagnose your charging system if it still charges juice to the battery.
Sep 28, 2012 | 2009 Kia Rio
A few drops of fruit juice got under the volume wheel and dried. Now the volume wheel won't turn easily. How do I get the volume wheel off to clean underneath?
Electrical contactsupply cleaner is best. You canto try drops of rubbing alcohol, which will clean the wheel and evaporate quickly. While you add the drop/s, turn the wheel.
Jun 04, 2012 | iHome Clock Clock Radio for iPhone iPod...
Battery checks out good but scooter won't start or even try to crank. Been sitting for several months
I have this bike. This is what i would try. Charge battery, replace old fuel with fresh fuel, manual says 91 Octane. You can drain old fuel out from fuel filter line, also good to replace fuel filter and spark plug. Spark plug is accessed from small panel behind where your ankles would be while riding. Fuel filter is above kick starter. Try and kick start, note its not the power of the kick that matters, its the position of the kick mechinisim - doesn't always have to be from the very top, you have to feel it be at a point just befofre it engages then kick. and DON't give it throttle when you're starting. If 10 kicks fail. Wait for the fuel to dry out for a few minutes, easy to flood with repeat failed starts...
Aug 13, 2011 | 2009 Lambretta Uno 150
I dropped my son's camara under my car and it was in the camara case, But it rain all night. When Iwent to get it the case was wet and the camara less is foggie but the camara turn on and off what do I...
Leave it in a dry environment for a few days until everything dries. I'm afraid the camera is permanently damaged if the rain has salt or chemical content. Hopefully it doesn't and it's just a matter of drying out.
Nov 09, 2010 | Cameras
I have a 2001 dodge grandcaravan 3.3 liter engine .the engine light came on so took it to autozone to have them read the error codes .they came up with failure of transaxle control module and pressure...
tcm is located in drivers side front wheelwell. will have to remove wheel and wheel well splash shield. unhook 60 pin connector and three screws holding tcm to vehicle. will have to set pinion factor and quick learn function via factory scan tool solenoid pacxk located below air cleaner on transmission facing front of vehicle
Jan 09, 2009 | 2001 Dodge Grand Caravan
Hi how are you
nope..that motherboard is most likely fried. got a warranty?
got backup for that Toshiba?
Feb 19, 2008 | Toshiba Satellite A60 Notebook
Wont turn on
Make sure you dont have the device locked. There is a switch on the top of the unit
Jul 26, 2007 | SanDisk Sansa e260 MP3 Player
Kodak EASYSHARE M340 Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
