Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Pool originally had electronic controls that were vandalized as result of foreclosure. trying to get heater to work. has Bd0 error on LED. what can I do?
  • 990 Answers
This is a very complacated problem due to the fact that you could have a number of different remotes and they all can hook up in different fations. to get the heater back to factory as they say (set up like it came from the factory) Is what you first need to do. If you run a search for Hayward pool products-owners manuals then follow to heaters it will bring you to a complete manual that can give you instructions to do this. If it get's to be to much you may have to get a repairman out but this is a good idea anyway to explain the pool to you. I hope this helps and good luck with it.
Posted on Feb 07, 2010
  • Kieran Ruppert Feb 07, 2010
IF error code when trying to start
Error IF is ignition failure.
Last page shows troubleshoot walk through ranging from low gas pressure to bad gas control valve to failed wiring etc
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Oct 28, 2012 | Hayward H-series Electronic Gas Pool...
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Hayward h series heater was working fine earlier this summer but just recently when we try to turn it on it won't allow us to change the mode from Standby to anything else. The display does not show...
Your unit likely needs the control bezel assembly replaced. It includes the control pad and the circuit board it attaches to. We currenly have one in stock for $229.60 + shipping (and tax if shipped to a Michigan address). If you would like to order it please contoact us thru www.arrowpools.net.
John
Aug 05, 2011 | Hayward H Series Electronic Ignition...
I have a air flow sw error, how do I trouble shoot it
That will usually be when to much air comes into the chimney that results in the flame going out, or, the blower assembly is not good anymore which will result in less air flowing thru the boiler.
I solved the chimney issue with raising the chimney above my outside wall (if it isn
Mar 28, 2010 | Jandy Lx Pool & Spa Heater - Electronic...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Code E05
E05 and E06 is the error codes for a faulty stack flue sensor. try changing the sensor first is the cheapest. if that doesn't work check for corrosion on control board in which case will have to change out board.
Apr 20, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
47 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
