Question about IBM ThinkPad T40 2373 Notebook
Worked fine yesterday - will not turn on today - kitchen
Worked fine yesterday - will not turn on today - power and power supply tested ok - machine is dead
  • 44 Answers
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Posted on Feb 07, 2010
HP Media Centre M7000 won't fire up
if its completely dead buy a new power suppley. else its the motherboard that is defective. check your warranty first.
thinks you can test is to remove all your memory and bios battery then try to start
Mar 07, 2012 | Computers & Internet
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
Fitted 1GB RAM yesterday, computer worked fine, today started okay, but later on it had turned the power off and will not power up now (emachne 32300
If you get no power, it sounds like possibly the power supply may be bad. If you can replace the power supply with known working unit, that would be a good start. If at that point you still get no power, then possibly the motherboard could have gone bad. Even without the ram installed you should get power through the board and when you try to boot you should get a beep or series of beeps. I would start with the power supply tho.
Sep 24, 2011 | E-Machines eMachines Refurbished EMA...
The machine will not turn on. It was working yesterday and today there is no power running through it. I have checked the outlet and there are no issues. Whats wrong with it and how can I fix it?
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Feb 28, 2011 | Keurig Elite B40 Coffee Maker
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
2004 Grand Caravan Front blower will not come on.
Check owners manual for location of heater blower motor front,check with a test light,if it's good locate blower motor under glove box and test the two wires for power when switch is turned on,if power is present motor needs changed.if no power check blower motor resister.
Nov 22, 2009 | 2004 Dodge Grand Caravan
My IBM Lexmark Wheelwriter 1500 is not turning on today (it worked fine yesterday) - what should I do?
If it does nothing no lights or beeps check the AC power source or the power cord. If the're OK you probably need a power supply or a board.
DickyO
Sep 24, 2009 | Lexmark Office Equipment & Supplies
Wii will not power on?
Bought a new power supply and now it works!
Dec 27, 2008 | Nintendo Wii Console
Asus A7V8X MX SE loooong beeps
It is either a memory issue or the power supply issue....
Try to reset memory modules.....If the machine still beeps after this and there is different memory modules installed try to remove each and boot(switch on).....to verify if any memory module is faulty.....if this doesnt work try replacing the memory.
If the problem persists try to verify if the power supply is ok.....
Nov 08, 2008 | ASUS A7S8X-MX Motherboard
IBM ThinkPad T40 2373 Notebook Logo
189 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
