Question about Whirlpool LHW0050PQ Front Load Washer
LHW0050P Whirlpool washer?
LHW0050P Whirlpool washer front loader-glass door
Any step by step instructions how to replace the rubber door seal?
  • 21 Answers
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Posted on Feb 14, 2010
Replace rubber seal
If you are referring to the gray rubber door seal (called the bellow), the following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
Apr 30, 2010 | Washing Machines
Seal blown out need to replace
If you are referring to the door seal (bellow), the following link explains step-by-step how to change the door bellow on a Whirlpool Duet front loader:
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rubber seal on whirlpool waasher
If you are referring to the rubber door bellow, the following link explains step-by-step how to replace one:
If you have any questions about this repair, or require additional assistance, please post back and let me know. I hope this helps you.
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My inglis front loader washer is leaking at bottom of the door....inside rubber area near leak feels gummy....any advice??
Scrub the glass on your door and the rubber boot. This works in almost every case. The washer gets a build up of scum on these parts and doesn,t allow a tight seal. In rare instances you have to replace the rubber boot. Good Luck, Appliance Specialists.
Jan 04, 2010 | Whirlpool Inglis IP4400 Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
The door leaks on my whirlpool front load model wfw8300sw03, looks like the door isnt sealing tightly, if I push on the door it stops lealing, any ideas?
you might have a bent door hinge, but most likely you have a worn door boot. its the grey rubber thing that the glass seals to.
try to lift up on the door to get the hinges back into place and if that doesnt work then you might need to replace the door boot.
look at the edge of the boot where the glass hits it. the glass must seal to the rubber and if the rubber is worn or torn then it wont seal.
not an easy piece to replace but it can be done. i wouldnt recommend trying it first as you will find it very tight to get your hands into and the clamps are hard to figure out as well.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
If I replace my bellow seal in my front loader will it leak?
It will not leak if you install it correctly. Click on the following link for step-by-step instructions on how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Inspect the new bellow PRIOR to beginning installation. Make sure the inner clamp that attaches to the wash tub is snug and not overtight. Also, make sure the rubber on the bellow that fits over the dispenser tube in the door area is installed past the flange (raised area on the tube). These are the common points that leak. Please let me know if you need further assistance. I hope this helps you.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal rip...
The rubber door boot (bellow) commonly wears out on these front loaders. A replacement will run you about $80 just for the bellow. Labor could run as high as $180 if you decide to hire someone to replace it for you. If you wish to perform the repairs yourself, post back with your intentions and I can provide you with step-by-step instructions on how to replace it. It is labor intensive as you will have to remove the entire washer front in order to do the job right. It IS possible, however, if you wish to pursue a repair option on your own. Just let me know.
PS I can also provide you with the part number if you reply with your washer model number (found along the door opening).
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
229 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
