Question about Whirlpool MH7140XF Microwave Oven
My whirlpool microwave's eject button suddenly stopped working. The button when pushed, does not open the microwave's door but just comes back to normal position when pushed
techman
  • 3130 Answers
SOURCE: Stuck Microwave door
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
Posted on Jul 30, 2006
  • 37 Answers
SOURCE: Door opener not working
The door latch must have broken in side which had stucked the door does not allow to open. Please arrange to call service engineer from the maufacturer's service center to fix the problem as proper alignment of the latches is must for safety measures.
Posted on Aug 03, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool GT4185SK Keypad does not work - oven starts as soon as door is closed
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
Another thing that can cause this is steam or grease / smoke getting in the controls. The best way to prevent this is to be sure your hood exhaust fan is on whenever you cook on the stove top.
If it does not dry out over time, it may need to be manually dried or blown out.
I've followed up to your by e-mail address to be sure I help you fully.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
localwonder
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
TheMazz
  • 78 Answers
SOURCE: I have a 10 year old MH7130XE Whirlpool microwave
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 18, 2009
Turns on when door is open; turns off when door is shut.
when mine did that it was the door switch had failed
Jan 21, 2016 | In Microwave Ovens
Microwave works while door open
Replace. Microwaves are cheap.
Feb 16, 2018 | DCS Microwave Ovens
MT4110RPQ-0 Built - in microwave in our Camper. (Serial FGR202317) Something happened and all of the sudden the microwave doesn't work at all. I do not know if buttons were pushed prior or not! Now...
Cdfacc, we're sorry to learn that your Microwave is not working. We'll be glad to further review your concerns. Please email your name, contact number, address, model and serial number to Whirlpool_Reviews@Whirlpool.com.
Oct 23, 2017 | Whirlpool Microwave Ovens
Hi! I like my [2001] Whirlpool MT2110SJQ 1100 Watts Microwave Oven very much, but have been having some occasional problems (possibly due to its age???). The first problem is that occasionally...
Arcing is a sign that the Magnetron is shorting out. Make sure cover, usually plastic, is installed properly covering Magnetron port. It keeps food from entering port. This is a dangerous condition, replace unit.
Mar 07, 2017 | Whirlpool MT2110SJQ 1100 Watts Microwave...
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
Microwave not working
May 29, 2009 | Whirlpool Microwave Ovens
Whirlpool MT$155SPS-1 microwave
Cajun1112, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Cajun1112), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool MH6150XLS Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Jul 30, 2006 | Whirlpool MT4070SK 700 Watts Microwave...
Whirlpool MH7140XF Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
