Question about Microtek C893 18.1" Flat Panel LCD Monitor
Yellow dispkay The display turns yellow. I think it may have to do monitor cable.
  • 44 Answers
The display turns to yellow when the blue colour is missed form cable. check the vga cable or may be it's from inside monitor. from the vga card. check the cable first then call or mail....
Posted on Feb 22, 2008
A photo of a yellow car is pink
The discoloration indicates you are missing one of the three color bands (magenta, cyan and yellow). Likely the display cable from your computer to monitor has a slight break in one of the interior wires.
Slowly move the cable around near the connectors and observe the picture. If you see it change, replace the cable. You can get one from any computer store for about $10-$15.
Aug 26, 2013 | ViewSonic VX1935wm LCD Monitor
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
It tuns green and when you turn on computer it turns yellow and then a light yellow and will not come on
Your monitor cable may be bad. This happens. Try a different cable.
If not, try a different monitor to ensure the computer is displaying. Also make sure everything is plugged in firmly (not HARSHly, just tight).
Also, try testing the monitor with a laptop. This will eliminate whether the monitor is shot.
Feb 28, 2011 | Westinghouse L1975NW Monitor
My monitor keeps turning yellow constantly. How do i fix this problem?
-check the monitor cable (vga cable the one with blue connector) for broken pins
-if there are broken pins replace the cable
-if not try another monitor cable or try the monitor to another cable
-if the monitor still turns to yellow after trying another cable or connecting it to another computer to problem could be with the monitor or the vga card
Nov 24, 2010 | Computers & Internet
The display has turned yellow.
Possibilities:
* bad connection of video-cable to monitor
* bad connection of video-cable to computer
* bad video-cable
* bad monitor -- connect to a different computer to see if it works, or displays the same symptom
* bad video-card -- connect a different monitor to see if the symptoms persist
It's probably time to responsibly-recycle that CRT, and spend $100 to buy a new 19-inch LCD monitor.
Oct 23, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
No video to tv or computer screen how to get it to display for menu set up?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} "Traditional Cables", are you refer to the red, white, and yellow cables?
Once you connected those from Cd/DVD to the receiver, did you then connect another yellow cable from the "monitor out" on the receiver, to an input on your television?
This is generally the step that people forget about.
The back of your receiver should have a "monitor" or "tv" output on it. You need to connect another yellow cable from it to an input on your TV, then turn your TV to that specific input.
That should do the trick.
May 25, 2010 | Yamaha RX-V1 Receiver
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
No yellow or blue color displaying
In a monitor like crt type. there are three colors amplifier. Red, Green and Blue. I think the Blue color amplifier is defective. Try check the biasing and also the transistor.
Feb 02, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Audiobahn AVM270Q (white out)
You have to check if Video cable from Flip Down Monitor has RCA Plug Cable or Super VHS Plug Cable.
RCA Plug is Yellow for Video= connected to Yellow Input of radio maybe loose.
Get VCR or Video Camera and connect Video Output with cable to Yellow RCA Plug of Flip Down Monitor.
Turn car on and VCR/Video Camera: you should get video to FL Monitor.
If not, then FLM is defective or has adjustment problems..
atdlee@netzero.com
Mar 07, 2008 | AudioBahn AVM270Q 7in Widescreen Car...
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Microtek C893 18.1" Flat Panel LCD Monitor Logo
127 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Michael Deni
Level 1 Expert
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
