Question about EA - Electronic Arts Command and Conquer: Red Alert 2 for Windows
When putting in the code to install it says it's incorrect.
  • 31 Answers
Dude i don't know if that legal but take this serial it should work to you;)
020736-428526-011875-6507
Posted on Feb 08, 2010
How to remove code sc792 ricoh MP5000b no finisher?
The machine does not recognize the finisher, but recognizes the bridge unit.
• Defective connector
• Defective harness
• Incorrect installation
• Defective harness
Mar 24, 2016 | Ricoh Office Equipment & Supplies
Radio keeps comming up with error cannot install radio code
usually means that someone has attempted to put an incorrect code in more than 3 times, just leave the radio and the ignition on for 60 minutes to reset, and then re-enter the code
Jun 17, 2010 | Ford Car Audio & Video
My Egypt copy does not install in my Windows xp sp3
If your code is not working then there is only a few things that will cause this problem.
1) the code is invalid or pirated
2) the code is not compatible with the version you are installing
3) the version you are installing is not to correct language encoded disc
4) you are typing the code in incorrectly, this usually happens with B and 8
5) the edition is incorrect (home and not pro)
6) The disc type is incorrect. Retail, upgrade and OEM codes do not work interchangably. OEM only works with OEM, Retial with retail cd, etc. This changed in Vista and Win7 but still remained with XP
Jun 03, 2010 | Montparnasse Multimedia Computers &...
I have a 1997 Chevy Surburban with a 350 engine - check engine light came on - code reads p1345 - it only came on when putting another distributer in - the other one was bad. Any ideas? Thank you!
this DTC determines,if the distributor is installed incorrectly,or if there is a mechanical malfunction in the engine. check the following items A loose or missing distributor hold down bolt A loose CMP sensor causing a variance in the sensor signal Incorrectly Installed distributor-1 tooth off in either advance or ****** positions Aloose distributor rotor on the distributor shaft excessive free play in the timing chain and gear assembly.
May 18, 2010 | 1997 Chevrolet C1500
Code PO732 2004 Ford Expedition
Trouble Code: P0732 (4.6L V8 VIN W Auto)
Incorrect Second Gear Ratio Print this code dataprint_icon_codes.gif Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Trouble Code Conditions:
Engine started, vehicle operating with 2nd Gear commanded "on", and the PCM detected an incorrect 2nd gear ratio during the test.
Possible Causes:
  • 2nd Gear solenoid harness connector not properly seated
  • 2nd Gear solenoid signal shorted to ground, or open
  • 2nd Gear solenoid wring harness connector is damaged
  • 2nd Gear solenoid is damaged or not properly installed
Refer to the mechanical section to diagnose transmission concerns
Trouble Code: P0732 (5.4L V8 VIN L Auto)
Possible Causes:
Refer to the mechanical section to diagnose transmission concerns.
Oct 26, 2009 | 2004 Ford Expedition
HI Please help me unlock my Nokia 3120C! It asks for the security code which I don't know. IMEI : 353102028122050
Try the reset code:
*#7328748263373738#
Then your securtiy code should be reset to :12345.
Please rate my solution if this helps.
Sep 10, 2009 | Cell Phones
I put a code on black berry storm and i z=went to
I think that putting different incorrect codes must have completely locked your phone for security reasons. You have to thus change your software and get a new one for your phone. Thank You.
Aug 14, 2009 | Cell Phones
It wont do my codes
The code could be incorrect or incorrectly put on there.
May 26, 2009 | Nintendo DS Lite Console
Sc code 672 with aficio 2090
Direct from the service manual:
• Controller board defective
• Controller board installed incorrectly
• Operation panel harness connection loose or incorrect
May 03, 2009 | Office Equipment & Supplies
EA - Electronic Arts Command and Conquer: Red Alert 2 for Windows Logo
89 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
