Question about Mamiya 645AF Medium Format Camera
Mamiya 645 AF back won't advance film.
Hi
I recently got myself a Mamiya 645 AF, it's a beautiful camera and worked like a charm the first couple of days, just as it should.
When I was on a trip and brought it with me in my backpack (loose, but carefully put in between some t-shirts etc.) I noticed when I took the camera out that the back door on the film back had opened, maybe it happened when I took it out, I don't know, but I closed it quickly, HOWEVER, when looking at the LCD screen on the back, instead of it showing the frame number it was showing this: -- , everything else seemed normal. I thought maybe it was because the back lid had opened or something, so I kept shooting, but the film never advanced to the end so I just took it out in dark and rolled it up manually, and there was clearly much film left.
When I put the next film in it would not even advance to the first frame, and it still shows the "--" on the back (I can still set the ISO settings) the camera just operates like it takes the picture, except for the film advancing. I have changed the battery in the film back, but still the same. I have also read the manual (and yes I have taken out the dark slide =))
Do anyone know what might be the problem? Is there something simple I'm just missing?
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Posted on Apr 05, 2010
2 Suggested Answers
  • 102366 Answers
SOURCE: I bought a second hand Mamiya 645 Af but as soon
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Posted on Aug 04, 2011
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to...
if the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
thanks.
Oct 11, 2008 | Mamiya Cameras
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
I just purchased a used back roll film holder for my Mamiya 654 Pro TL, and I cannot pull the dark slide out. This dark slide has a blue handle, where my other back's dark slide has a red handle, and...
It's been a while since I used a mamilla 645, so forgive me if this is wrong, but I seem to remember the dark slide would only come out with the camera wound on, ready to take a picture.
Dec 26, 2017 | Mamiya 645 Pro TL Medium Format Camera
Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Jan 09, 2011 | Mamiya 645 Pro TL Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Jun 15, 2009 | Mamiya 645 Pro 80mm F2.8 N/L Lens
Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Jan 07, 2009 | Mamiya 645 Medium Format Camera
Mamiya 645 Super mirror locked in open position
My mirror somehow got stuck open too, I removed the power winder and grasped the pins in the middle of the silver wheel underneath used to wind the camera. Turn this clockwise until it stops and shutter is completely closed. Test fire camera after. If it doesn't work make sure you wound it all the way.
Nov 25, 2008 | Mamiya 210219 for 645 Pro/Pro TL/Super...
Shutter stays open on mamiya 645 M
Get any crud from the battery out of the works with pH-neutral stuff and q-tips or lint-free towels, and see if it works (without film; might as well check current drain with a bench supply instead of a battery, too) once you've done a satisfactory job of that.  Then visit a shop so they can see if the shutter timing is tolerable...and perhaps sometime you can load film in again.
Jul 31, 2008 | Mamiya 645 Medium Format Camera
Mamiya 645AF Medium Format Camera Logo
666 people viewed this question
Top Mamiya Photography Experts
Tony
Parshiv Luthra
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
