Question about Yamaha CDC-555 5-Disc CD Changer
Yamaha CDC-555 5-disk CD changer. Drawer will open but needs a push to close. I think it needs new belts. Where can these be bought? Any other suggestions welcomed.
5 Suggested Answers
SOURCE: I need a new belt for my Yamaha cdc-615. The belt
Jusy had the same problem. The player worked fine until one day I went to use it and the tray would not open. The belt had streched and was too loose. Since the player is quite old finding a replacement belt was next to impossible. So I went to the local hardware store and bought a Danco #56 rubber O ring (Stock# 35770B, 1 1/2 O.D. x 1 3/8 I.D.) I replaced the belt with the O ring and it works perfectly. The original belt is a V belt but the O ring seems just fine. Important that you do not get one any smaller because it may stress the motor drive shaft and bend it.
Posted on Dec 27, 2009
  • 211 Answers
SOURCE: On my Yamaha CDC-625, I can push the open/close
The most common problem is a slipping belt.
You have to open-up the player to check it.
If you're not familiar with it, then please don't.
It's not such a big problem, look for a local repairshop.
HNY, Gerard
Posted on Jan 02, 2010
  • 141 Answers
SOURCE: need drawer belt for Yamaha cdc-805 CD changer
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Posted on Apr 07, 2010
  • 62 Answers
SOURCE: CD changer does not open
Loading belt need replacment
Posted on Aug 23, 2011
Sony cdp-ce525 drawer won't open
How old is the DVD player? I have a Yamaha 5-disk player and the rubber drive belt that wraps around the drawer motor and connected to the pulley for the drawer was stretched out and useless. Just bought a new one online and voila!
Jun 16, 2014 | Yamaha CDC-745 5-Disc CD Changer
Why does my yahama cdc-505 cd changer not play cd, or change tracks
This is a result of the deck kicking out you disc as an unacceptable media. This usually means that it can not read the data on the disc or the necessary TOC (Table of Contents).
The other possibility is that your draw in detection switch has gone bad and when the processor- control type, tries to load a tray or close the drawer it is not getting the door closed signal. Depending on how the unit is programmed it might just sit there and do nothing or in your case throw the disc back out.
It is kind of telling you it wants to go see a Technician.
It could also be a bad belt that loads the Pickup assembly- it might be good enough to move the drawer in and out but the Pickup assembly needs more torque and it might not be there.
Dec 13, 2012 | Yamaha CDC-505 5-Disc CD Changer
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Try and parts list for itwill not open were do i get new belt
Remove the old belt and take it down to a tv repair shop to have them size up a new replacement. They usually carry a large selection of belts for almost any job.
Mar 17, 2011 | Yamaha CDC-555 5-Disc CD Changer
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Cd player stuck
Hi..
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Nov 23, 2007 | Yamaha CDC-585 5-Disc CD Changer
164 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
