Question about Sony STR-DE585 Receiver
How do I connect my ipod to my Sony STR-DE585 receiver
    Scholar:
  • 127 Answers
Use analog audio cable with jack connector on one side (to the iPod) and 2 RCA connectors (white/red) on the other end for the analog inputs of receiver.
Posted on Mar 03, 2010
I have no sound from front speaker channel anymore.
Your front channel needs to be rebuilt. Since your unit did not go into protect, you probably only have a blown resistor, or diode.
Apr 04, 2011 | Sony STR-DE585 Receiver
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
How do you reset the protection mode
The protection function has been activated because it has sensed an output load problem, turn receiver off and remove the speaker wires, this will reset the protection circuit. Now! turn the device on and turn the volume right down, if the protection mode stays off it indicates a short in the speaker wire or one of the speakers, but! if the protection circuit comes on with "the speakers and wires dis-connected" it means there is a short in the audio outputs in the receiver itself, this can only be rectified by having the parts replaced.
Mar 02, 2011 | Sony STR-DE585 Receiver
We heard loud music on it the other day and suddenly it just stopped working, we did not hear a sound and we did not smell anything. Now it just can't be turned on again.
I assume that its fuse which is on the power line has blown out..
some fuses are located inside the cabinet that can be reached by unscrewing 4 screws on the sides.Any electrician can replace it.
Please check it out.If this is not the case please give more clarification.
Regards
Oct 22, 2010 | Sony STR-DE585 Receiver
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
Want to play my ipod through sony str-de135 receiver
Get a headpone to rca cable (radio shack or best buy) and use any input on the rear of the receiver except phono. You will need to turn the ipod to near max volume.
Nov 28, 2009 | Sony STR-DE135 Receiver
Sony str de405 receiver...was working fine, now no sound
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
May 14, 2009 | Sony STR-DE405
No voice audio
Have you selected coax mode with the input button?. If so you may need to play around with the setup buttons. Can't give anymore advice as I've lost my manual. Good luck
Dec 26, 2008 | Sony STR-DE585 Receiver
Playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
Sony STR-DE585 Receiver Logo
359 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
