I have the toshiba 42HL67 Tv and Need the Base
I have the Toshiba Regzam #42HL67 TV and Need the Base stand .
Try toshiba.partstore.com
Posted on Feb 07, 2010
How do I remove the stand from toshiba tv? Model# 42HL67
I believe that there is 4 Phillips screws that hold it on remove them and stand should come off
Mar 02, 2015 | Toshiba Televison & Video
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
Nov 02, 2011 | Toshiba Televison & Video
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
42hl67 has a continuous blinking yellow light in 3 blink intervals, how do I fix this?
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
May 09, 2010 | Toshiba 42HL67 42 in. LCD Television
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
stand to avoid damage to the LCD panel.
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
be removed without tools.
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Televison & Video Logo
236 people viewed this question
Top Televison & Video Experts
Electro Med Services...
