Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Fridge making a toc toc noise once in a while for at least a minute then work well and restart the toc toc noise every 20 min.
2 Suggested Answers
  • 942 Answers
SOURCE: refridgerator make a noise every 3 minutes
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Posted on Mar 31, 2010
My whirlpool fridge starting make a loud noise on and off
You could have a ice block fan, take all your food out and keep it cold, then unplug the unit with doors open and let it defrosts 3-4 hours if this solves the issue you should do this process once every 2 months. If not is time for special service
Aug 19, 2016 | Whirlpool Refrigerators
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
GE Monogram side by side model z1s420nmc is making a ratlling noise once in a while
Just to give you an idea about what might make that noise check my video out. A list You will see how compressor mounted and check Your own fridge from where noise might come from.
Jan 04, 2012 | GE Monogram Side by Side Refrigerator
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Every 20 mins or so the fride--a11 yr old
is it shutting off when it makes that clunking noise? if so, thats the compressor making the noise. the motor inside the shell casing, which is suspended on four springs, is banging agasint the shell casing because one of those springs has stretched or broken. You need to replace compressor. if its been happening for a while, i would start looking for a new model. if its more recent, and not very loud, you haver more time, but in either case, it could just cease up at any time. to hgave your compressor replaced, and unless your an HVAC tech you should most assuredly NOT do it yourself, its quite expensive, at or near the cost of buying a new one.
Feb 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Fridge not cooling down
The most likely cause is a gas leak . Call a technician.
Jan 22, 2008 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
