Question about ION Audio Vinyl Recording Turntable
I recorded my first vinyl into i-tunes with a mac and the sound
On playback is horrible. What am I doing wrong
    Sergeant:
  • 226 Answers
Hi, when you say horrible, what do you mean?
Is it distorted?
is it too thin and bright?
Is it dull sounding?
Have you got it connected correctly?
What software are you using?
Let me know.
Regards - Anthony
Posted on Feb 07, 2010
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
I'm trying to use my ION TTUSB1010 Turntable. I don't get any sound when I record or Playback. I've got Playback set to Sound max digital Audio and sound recording at USB Audio CODEC. I just get feedback...
http://dl.owneriq.net/b/b15dd636-9b8d-4d78-8fd0-4bb2d82774f3.pdf
Above is your user manual, perhaps this can help?
If you are getting feedback, that's because there is too much "Coupling" between the Mic & Amp, You may need to use a Mic, with LESS drive.
Are there any Firmware upgrades?
You also need to ensure the Recording CODEC is the same as the playback CODEC, that's a must do.
Nov 29, 2010 | Computers & Internet
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
Do you need i tunes or canm you bypass it i only have dial up and it wont support it 18 hr download so can i bypass it to do my vinyl recordings have vista programs thank you
If you can hear the sound playing back from the turntable in your computer you don't need I-Tunes. All you need is a recording software, I recomend Magix Audio Cleaning Lab. It will record the signal from your deck and then you can clean it up remove all the clicks and bad noise and the save it to any file format or make CD's with it.
You can buy it cheap from Amazon.
May 02, 2010 | ION Audio Vinyl Recording Turntable
Backpanel socket for microphone is not recognised. Speaker socket is alright.
in order to hear sound on the microphone you need to check the Mixer settings as the default setting for microphone (for playback) is mute as you would get some horrible feedback..
double click on the speaker icon in the bottom left and chose properties from the options menu you may (or may not) have the option to select microphone for playback, however there should be a setting for recording which should give you a slider to set the recording levels for the microphone, use sound recorder or other recording software to test microphone is working
Apr 13, 2009 | Intel Motherboard
Where can I get an old vinyl recording repaired and converted
yes it can be done i have done this many time for many people... you will need to find someone who knows what they are doing with delecate vinyl... you could either locate a specialist on the web who will be able to take the track off the record and remaster it before it goes on the cd taking out all the clicks and cracks sounds and any imperfections in the sound caused by the damaged vinyl. this option could be expensive. Just type "vinyl to cd services" in google and the search should yeal what you are looking for.
or...
you could ask any good dj/bedroom dj you know or a friend might know to do it for you, as any good dj will know how to treat a damaged record and will certainly be able to transfer on to cd for you. although... depending on the dj's skill level he may not be able to remove any click sounds or audible imperfections? throw him a tenner and supply the cd im sure he will be happy to help!
Feb 14, 2009 | ION Audio Vinyl Recording Turntable
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
Vocal recording
If you are trying to make your voice "fit in the music" better is there a sync button ? If it is the tone quailty as I was horrified at what I sounded like the first time I heard my self, then practice voice lessons and playback more practice. Remember to sing on the vowels.
Oct 24, 2007 | Tascam DP01 All-In-One Recording Package...
ION Audio Vinyl Recording Turntable Logo
264 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
