Question about Baby Gear
My frony tyre and bcak tyre have blown up due to too much air being out into them. i require a new tube and tyre for frony wheel. For the back wheel I aso require the rim as it was damaged when tyre exploded? can you help? thanks
Did you ever find a rear rim? I just had the same thing happen at the mall?
Posted on Feb 07, 2010
How to Patch a Bicycle Tube?
buy a new tube.
Pull out tube
Pump air in to it
put under water
notice were are leaks from
using a bicycle patch kit
sand tyre around hole
glue patch over hole
wait for glue to set
check no nails, glass embedded in tyre first before you
put tube back inside tyre
put tyre back on wheel
https://www.youtube.com/watch?v=x5x7GIc0e6g
https://www.youtube.com/watch?v=WG7Y1eSDsNA
Oct 20, 2016 | Cycling
How do i change tube on the wheel for my pride prusuit 36 sport? I have it removed and screws in the center of wheel out
Deflate the tyre completely by removing the tyre valve only then undo the nuts on the outer bolts take the two halves of the wheel apart remove the old inner tube noting carefully how the valve was placed through the wheel. Check the wheel interior and rims for rough or rusty patches, clean it up fit the new (empty) inner tube making sure that nothing is pinched reassemble the wheel halves together and be sure to fully tighten all nuts before fitting a new inner tube valve and you are ready to inflate the wheel. Do this in stages and gently bounce the wheel to settle the tube and rims then continue inflating continue a bit beyond the recommended tyre pressure and then release the air to the optimum pressure.
idea. If you have uniform wheels, consider buying a 5th wheel as a spare and fit it to the tow bar/ accessory attachment point behind your seat. I've done this on my venerable Pride Celebrity XL8.
Jul 14, 2016 | Pride Health & Beauty
I need a place to change my dirtbike tire and tube
get 4 bricks and place wheel on top , release air , stand on the tyre to push it off the seal , both sides , then carefully lever tyre over outer edge , make sure to push one edge of tyre in and DONT CATCH THE INNER TUBE ! take inner tube out and do the same the other side ! get new tyre and replace in reverse order !
May 01, 2014 | Motorcycles
I have a flat tire on my scooter which i would like to fix but unable to get the rim apart can you help me
Yes. Be careful! Only remove the wheel's central nut, NOT the outer ring of nuts yet. Remove the tyre valve slowly and with care to empty the inner tube. Remove the wheel by tapping the rear of the wheel as necessary - be careful to remove the axle key and keep it safely to one side. Remove the remaining wheel nuts split the wheel and remove the tube from the tyre and wheel. Check the wheel inner surfaces for rough spots and clean. Insert the new tube and making sure that nothing is pinched reassemble the wheel inflate the tyre to the recommended pressure in stages gently bounce the wheel once or twice to help the tyre to seat properly. Inflate to just above the recommended pressure and release surplus air. Offer the wheel up to the axle with the wheel and axle key slots exactly opposite each other. Insert the "key" in the slot and gently hammer it home.
Voila, you have done it!
Jul 30, 2013 | Pride Health & Beauty
I have aflat tire on my scooter that i would like to fix but i cannot get the rim apart the nut just will not move
Jul 30, 2013 | Pride Celebrity X 4-Wheel Electric Scooter...
How to remove the front wheel on bike to change inner tube
If the wheel is quick release all you need to do is turn the lever one half turn clockwise, and the wheel should drop out of the forks.If , however, it is retained by nuts you will need the appropriate size spanner - slacken the nuts and drop the wheel out. Open the valve ( or if it's a car type- depress the pin to let the air out). Next you need a set of three tyre levers (from your local cycle shop) Carefully ease one side of the tyre away from the rim. If there is a lock ring on the valve, undo it.Pull out the inner tube and replace with a new one. Ease the tyre back into position being careful not to trap the new tube.Blow up the tyre, refit the wheel,tighten the nuts or quick release system.Ensure that the wheel is secure before riding the bike.
Sep 11, 2011 | Cycling
Huffy green machine front tire is flat
There are nuts at each side of the axel, on which the wheel turns. These may have to loosened by a spanner or may have quick release levers. If there are levers pull them outwards from the wheel and you can then turn them to release the wheel. Let all the air out of the wheel. Then insert 2 levers under the edge of the tyre, about 6 inches apart and pull the tyre out over the rim of the wheel. Put in your finger and pull the rest of the tyre over the rim. Then lever the other side of the tyre over the same side of the wheel and remove the tube. Replace the tube ensuring that the valve for pumping is in place first. Replace the tyre as far as possible by hand and use the levers for the final few inches taking care not to trap the tube between the lever and the rim of the wheel as this could cut the tube. Place the wheel back on the bike and tighten the nuts.
Jul 17, 2010 | Cycling
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
I cant remove the tyre form my wheel.
I personaly wouldn't recommend loosening any spokes,ive never had to do this and you could get into all sorts of bother trying to straighten up the wheel afterwards.
First make sure that you have let down all the air out of the inner tube (if theres any left).Next with both hands grab the tyre and make sure that the bead of the tyre (where the tyre sits in the rim of the wheel) is loose and away from the rim (sometimes the bead can get stuck against the rim and this will make it much harder to remove the tyre).Do this all the way round the tyre and on both sides.Now if you have a very good quality tyre lever,wet it slightly and the tyre casing as well with some soapy water and try to lever the tyre bead up and over the edge of the rim of the wheel.While holding this position use a second tyre lever in the same way about 2 inches further away and do the same thing.Once you get both levers down you should (hopefully) find the rest of the trye starts to come off a bit easier.Just wiggle and push one of the levers along the bead of the tyre until most of the tyre is off and your there.
Putting the tyre back on is just as much fun!Only try not to use the tyre levers as much as you can very easily damage the new inner tube that your trying to put in.So eat 3 weetabix and you should then have the strength to attempt this.
Good luck
May 21, 2009 | Maxxis Minion Dhr Single Ply Freeride...
Every other week i'm getting flat tyres very unexpectedly. The tyre pressure warning light comes on but instantly the tyre is completely flat. Apparently its due to corrosion of alloy rims, how can i get...
A temporary workaround/remedy is to put innertube inside the tire. Even if the alloy rims could not longer provide a good air tight seal, the inner tube would still hold the air. You may need to specify the tire size and width. Additionally, you may want to ask your tireman to likewise install a buffer of some sort between the innertube and the alloy rim. This is to prevent the any sharp portion of the corroded alloy rim puncturing the inner tube. Some local tiremen use a cutoff/old inner tubre as buffer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 15, 2008 | Mini Cooper S Cars & Trucks
Baby Gear Logo
61 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
