Question about Corel WordPerfect Office 12 Home Edition (WP12ENGPCHE) for PC
When I try to run a template-macro for the fist time each day, I get the message that "PerfectScript12 has encountered a problem and needs to close..." I then have to reinstall WP12 whicy solves the problem for that day. I have used WP12 for many years and this only started recently.
  • progar Feb 10, 2010
    I have tried your suggestion several times now and I still have the same problem. I uninstalled WP12 and reinstalled it. This was very difficult because most of the time I get the message "Error 1500" the program is already running. I have to keep restarting the computer in order for this to stop. I need another solution!
    President:
  • 1,871 Answers
Hello:
First try to scan your system for viruses ! If it's free of viruses then uninstall the [ PerfectScript 12 ] and reboot your system , then install it again and reboot system once again and problem will be solved .
good luck .
Posted on Feb 10, 2010
  • 19,396 Answers
Hi.
If the problem happens always with the same macro, then it is the Macro that is creating an issue with system settings.
If you get the problem with any macro, and you already reinstalled WP, then the problem is the system. In that case, if you use Windows, try creating a new user with administrator privileges. Uninstall WP, and reinstall after logging in with the new user, to test WP.
If you use Vista, to install WP, instead of using auto-run, locate installer file on CD, click right button of mouse on setup file, and choose "Run as Administrator" from drop-down menu, after ensuring you had done log in with the new user.
Regards.
Posted on Feb 07, 2010
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
Word 2007 saves and closes normal.dotm everytime I close it. It doesn't ask for anything, but it shows as an opened document in Word and start menus list.
It could mean that the normal.dot file is corrupt.
Try this:
1. Do a search for normal.dot
2. when found, change the name to "normal.dot.old"
3. restart your machine
Good Luck !!!!!!
Jul 21, 2009 | Microsoft Office Professional 2007 Full...
"this modification is not allowed because the document is locked"
Rename all instances your document template files (Normal.dotm or Normal.dot) to prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened, rename your global template (Normal.dotm or Normal.dot). Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
My MS Word 2007 has been giving me problems for about a week or so. It's part of MS Office Home and Student 2007. The problem is that it keeps freezing up on me and I lose typed text. Eventually I can...
Rename all instances of your document template files (Normal.dotm or Normal.dot). This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.Renaming the template will let you quickly determine whether the global template is causing the issue.
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
Flash template...how ot add audio clip
well, if your having a hard time adjusting it in flash mx, you can try to convert the flash file into any other video format like .avi then add them up into any video maker editor and try to adjust it through there. then just convert it back to flash. sounds silly but its easier that way i guess if your really having a hardtime adjusting it with macro.
Feb 05, 2009 | Computers & Internet
Normal.dotm Won't Adopt Macros & Code is Seen as Full of Bugs
It sounds like your Anti-Virus or Spyware is blocking and won' t allow access, it thinks its harmful, try turning off the Virus software installed, do your thing and then turn the software back on. If thats not it then your Software is damaged and you will have to install a new copy of Office. Good Luck.
Oct 27, 2008 | Compaq Presario 5000 PC Desktop
I cannot get the Page Header - OnFormat feature to fire
Hello Friend,
This is Iqbal we had a chat session on yesterday. I was hurted badly after veiwing your comment, that i "was put you on circle", I am sorry for that.
Anyways I have tried and I feel very much pleasure that it works.
What I did see: I have marked the option I have selected with red circle/regtangle.
Open The Access 2007
563db35.gif Choose Local Template -> Students
Then a blank screen appeared.
Then click on Navigator Pan (if it closed)
Then Select "All Students" report
b6310c7.gif Then Selec Page Header and then On Format button in Event
Then Choose Builder Dialog appeared as follows.
Select Macro Builder and Clicked on Ok button.
Then select MsgBox in Action List
Then I put a message 'Show Me' In message and click on Run.
Then save macro dialog appeared.
As well as I save the event fires First Time. (As it executed).
Thats all the stuffs which we needed to do.
Now Goto View and Select 'Preview' (To execute the Report).
7d94572.gif Then Event will be fired two times.
Feel free to mail me at iqbal_delhpidev@yahoo.com
Thanks
Friend I think it will help you.
Please post your feed-back.
Thanks again
Iqbal
Apr 30, 2008 | Computers & Internet
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Copying Microsoft Word macros to new computer system
Macros are stored in one of two places, Irene - and you decide where and when you create one. When you select Tools -> Macro -> Record New Macro you’re prompted to either create the macro in the global template (normal.dot) file, or the document you’re currently working on - by default, normal.dot is selected so that the macros are available in all documents you create.
Your normal.dot file is also where all custom styles, toolbars and autotext entries are stored, and it’s possible to transfer all of these - plus your macros - from one machine to another courtesy of Word’s Macro Organizer tool. The walkthrough below explains how to access it and back up your macros to a file you then transfer to your second PC before copying those macros into the normal.dot file on that computer so the macros are accessible from there too.
While this tool is the best way to transfer macros, or other individual elements of your normal.dot file (just select the appropriate tab to transfer styles, toolbars and autotext entries in exactly the same way), if you’re migrating to another PC you may wish to take all your settings with you. If you have Office 2000 or later you can use the Save My Settings Wizard to back up all your Office customisations - including the normal.dot template - and then use the same wizard on your new computer to restore them to the version of Office installed there.
Office XP and 2003 users will find the tool installed with Office -access it from the Microsoft Office Tools menu on the Start -> All Programs menu; Office 2000 users need to download it from here. It’s called the Microsoft Office 2000 Profile Wizard here.
Nov 03, 2007 | Compaq Presario 5000 PC Desktop
Corel WordPerfect Office 12 Home Edition (WP12ENGPCHE) for PC Logo
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
