Question about Sony DAV-S300 System
Can the dav s300 speakers be set up without plugs?
I want to hook the speaker system up without using the plugs is there a way to do this?
    President:
  • 3,085 Answers
Yes, they can. The lead with the color band is +
Posted on Feb 07, 2010
I need to find speaker connectors for Sony DAV S300
Check eBay "sony DAV-S300" check the 'include description' box. Several there.
Jul 16, 2011 | Sony DAV-S300 System
The DAV S300 system I have is almost 10 years old. And I have changed the lens once before. Now it's again giving me a 'no disc' error whenever I insert any disc. Instead of changing the lens...
You're not likely to find a non-boxed-set control center amp that can safely drive 3-ohm speakers like yours.
HTIB's aren't meant to mix and match with anything. Proprietary speaker connections instead of stripped bare wire are a tip-off.
If you really like the speakers you could troll the auction sites for a new central unit.
Jul 07, 2011 | Sony DAV-S300 System
How to plug speakers up to amp
Depending on what system you have the answer could be different. I see a theatre system on screen so I will address that. You should have five speakers and an amplified woofer. Two speakers get connecte to the front left and right connections. This used to be standard stereo. Two speakers get hooked up to rear left and right. Keep in mind that they are talking about left and right from the listeners perspective. The final speaker gets hooked up to the center connection and should be placed on top of the viewing unit. The subwoofer should be connected to the subwoofer port and placed to the right of the screen from the viewers perspective. Hope this helps. Let me know.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Sony DAV-S300 System
CAN I HOOK THIS UP TO HD TV FEED WITH A PVR
henknm
If your PVR has an Optical Output then you will be able to hook that to your SONY DAV-S300. If it does not you will just be able to use the standard analog stereo connections. I included a picture of the Optical port on your SONY DAV-S300.
Issken
Jan 18, 2010 | Sony DAV-S300 System
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
Sony DAV-S300 volume is unchangeable from either remote or knob. Any ideas?
Is the sound coming from the speakers you have installed, or from the speakers on the TV itself?
Dec 19, 2009 | Sony DAV-S300 System
I just installed a Denon 1610 A/V. I used my speakers from a older Sony 5.1 channel home theater system (DAV-S300). I got all the speakers to work except for the subwoffer. In order to hook-up the SW, I...
If you go to Manual setup/ select speaker setup/ select bass setting/ does it show LFE? If it does it is sending to main speakers only and you'll need to change to LFE+Main.
Oct 20, 2009 | JBL SCS135 System
COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Oct 15, 2008 | Sony DAV-S500 System
Need one set of speaker wires.
If the wires have just bare ends plugged into spring-loaded contacts then you can get some twin lead from radio shack or walmart. Just make sure you match the colors from the stereo to the speakers
otherwise you might not get real stereo or surround.
Jun 02, 2008 | Sony DAV-S300 System
No speakers?
if you are trying to get rid of all the speakers & just hooking up the sound to the tv speakers, what you need to look for on the back of the dvd system is you need to find an audio out. I know the is one or two audio input, but I do not think there are any audio outputs. I don'e think you can get sound out of this system without your speakers hooked up. sorry.
Oct 31, 2006 | Sony DAV-SA30 System
Sony DAV-S300 System Logo
205 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
