Question about Texas Instruments BA-II Plus Calculator
Texas instrument ball 2 plus
I have problem with my calculator,i just reset it and now it is not working properly,is there any setting up that i need to do in order for my calculator to calculate correctly???
Are you talking about TVM calculations? If so, you need to change your payments per year setting (P/Y) from 1 to 12. That should fix it. Hit 2nd, (I/Y), 12 and then ENTER.
Posted on Mar 24, 2008
Tvm not working properly
It's a little tough to diagnose with what you've given. Could you post all the numbers you're putting in, the result you're getting, and the result you expect?
Sep 12, 2013 | Texas Instruments BA-II Plus Calculator
How to remove a setting off the calculator
You reset the calculator to defaults. Press [2nd][+] to enter (MEM) configuration. Select 7:reset. Under the RAM heading, select 2:defaults.
May 09, 2012 | Texas Instruments TI-83 Plus Calculator
Need to solve sin-1((29sin47)/21)
First, make sure you have the proper angular mode set. Then press
2ND [SIN^-1] 2 9 SIN 4 7 ) / 2 1 ENTER
Jul 25, 2011 | Texas Instruments TI-84 Plus Calculator
I reset my Ti 84 plus Calulater on acceident is there a way to reset it to factory settings?
Press 2nd button, the press 7, then 1 and then 2. This will reset your calculator.
Jul 15, 2011 | Texas Instruments TI-84 Plus Calculator
How do i reset my Texas Instruments TI-84 Plus Calculator?
Firstly turn the calculator on and press the "2nd" key. After you do that press the plus key (+). A little above that key you should see the world "mem". When you see the screen titled "Memory" move the cursor all the way down to the option that says "Reset". Once you do that you can choose to reset either the RAM memory or the factor settings. Hope this helps.
Feb 27, 2011 | Texas Instruments TI-84 Plus Calculator
I am using Texas BAII Plus. The problem is when I try to calculate the NPV, N, PV,PMT, FY. it does not provide the right figure. It was ok until this morning. I think I might press something wrong....
Check the BEGIN/END setting (2nd [BGN]) and the number of payments per year (2nd [P/Y]). If these are set correctly, could you post the problem you're trying to solve, giving both your results and the expected results?
Oct 27, 2010 | Texas Instruments BA-II Plus Calculator
Kids jumbled up my T1-83 at school. solve doing a re-set, please.
To reset the calculator
Turn it ON
Press [2nd][+] to access (MEM).
Press [7:Reset]
Press[1:All Ram]
Press [2:Reset] [ENTER]ENTER]
Press [CLEAR] to erase Ram Cleared message.
Hope it helps.
Nov 13, 2009 | Texas Instruments TI-83 Plus Calculator
My ccalculator won't graph anything. I get the error messge Inval
Press the 2nd button, then the plus button, then 7, then 1 and then 2. This will reset your calculator to factory settings
Jul 23, 2009 | Texas Instruments TI-84 Plus Calculator
Texas T1-83 Plus Calculator PROBLEM
Adjust the contrast by pressing and releasing the 2ND key, then pressing and holding the Down key to reduce or the Up key to increase the contrast.
Apr 02, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments BA-II Plus Calculator Logo
326 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
