Question about Siemens Ovens
Siemens HB 905 - oven is heating up but fan isn't coming on. Any ideas as to what the problem might be?
4 Suggested Answers
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
tborn6
  • 700 Answers
SOURCE: fan working grill working just no heat in siemens oven
hello the first thing that we need to look at is the electrical box thats is outside and see if there are any more braekers tripped. the clue is that everything work except the heat. thats 208/230 volt and the rest of the oven is 115 volt. e sure to take the breakers and push them all the way to off then back to the on position. if thats is the problem now you are going to have to call a service man to check out what is shorting and causing the breaker to trip.
Posted on Dec 23, 2008
  • 197 Answers
SOURCE: Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Posted on Oct 09, 2009
Testimonial: "Thanks, that helps. Will it be easy to fix? can I do it myself? "
Fan oven comes on but no heat any ideas?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 18, 2011 | Electrolux Ovens
I can't get my Siemens oven self cleaning feature to work. I first set the dial to the cleaning position. I then try and set the temperature dial. As soon as I turn the dial the beeper sounds with the...
You have to take everything out your oven all the removables , then turn knob to pyrolyse and the other knob to 1 for mild cleaning 2 for medium and 3 for heavy cleaning
Jan 10, 2011 | Siemens Ovens
Thermostat on siemens hb 750.50 b
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodlg.htm?Maktx=hb750&eshoptype=S
use link to find unit part breakdown, check your Enr from the rating plate as the number you have posted is incorrect. (no spaces and no full stops in Enr)
Sep 04, 2010 | Ovens
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Fan working grill working just no heat in siemens oven
Dec 23, 2008 | Ovens
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Ovens Logo
132 people viewed this question
Top Siemens Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Siemens Oven Expert? Answer questions, earn points and help others
