Question about Toys
I NEED TO KNOW HOW TO CHANGE MAIN BLADE CONNECTOR
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details and the complete make and model number of the product.
Thanks for using FixYa.
Posted on Feb 15, 2010
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Can i change the Lincoln 1000 Main Blower Motor my self if i get the right parts?
Yes, if you are a bit handy man and you have the following tools,
1.Set of rachet set
2.A couple of scrow drivers and pliers
3. A blow torch to heat the core of the fan blade.
4. A pully remover.
Herr is a question
Why do you need to change the main blower?
is it noisy and you need to change the bearing?
is the motor burnet out? this case is one out of 100 case.
let me know.
Thanks
Harry@pizzaequip.co.uk
May 20, 2010 | Lincoln Conveyor Oven - 1133-000-A
I have a Sony KV-36FV1. Do I need to discharge
Hi
No ,but make certain that set is unpluged from mains before removing back if you do have to removed the eht anode connector for any reason then discharge by inserting s screew driver blade with a wire and crock clip attached clip to braiding on crt bulb> if a fuse is blow find out why before replacing mighy be faulty diode or power tranistor.
regards windyhouse
Apr 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Replacing wiper blade on 2007 Vanden Plas
Let the tube squirt washer fluid directly on the windscreen, if it does a poor job then you may have to make a flat nozzle. Your local auto house supply should have some small plastic Ts for coupling hoses, find one that fits, cut it long enough to be fastened to the wiper blade with black tape or epoxy, heat the end and flatten with a pin to make a small passage. Use a cheap pair of gloves and use your hand to flatten the softened plastic. The only McGyver trick I know for this!
Feb 21, 2010 | 2007 Jaguar XJ Vanden Plas Sedan
Changed main belt in machine and need to know
check earth wire is on motor, heater element and if metal tub fitted then this will be earthed aswell
Feb 16, 2010 | Electrolux AWW1017 Front Load Washer /...
9077 eagle justs spins and will not lift off ground.
i need blueprints or repair plans for the double horse 9077
Nov 29, 2009 | Axial Syma 9086 Helicopter
Phone is dead, battery fully charged. Need instructions on how to disassemble the phone to look for obvious problems.
From the back of the phone, remove 1 screw @ the top/center. Take the battery cover off, remove the battery. Remove 4 screws. With a medium size blade
screwdriver, gently pry the case apart at the battery charger hole. Just pry the plastic, not the connector case. Then with a very thin precision blade screwdriver, work your way around both sides of the case. Note: there is a connector that goes to the display portion of the phone. Once the case is open, gently pry the connector of the main circuit board. There will be a keyboard cover, 2 side button plastic pieces, 2 side button circuit boards, the top plastic cover, and the bottom main circuit board.
Good Luck
Russ
Jul 13, 2009 | LG VX5400 Cellular Phone
Change wiper blades
you are changing the blade not the arm oem connector dont need to be touch
Jul 01, 2009 | 2006 Jaguar XJ8
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
No boot or wake up
Chances are you need to change the power supply,, but first you need to check to see if its workingm this is quite easy
1.) unplug it
2.) remove the power connector from the main board
3.) on the power connector is a green wire(ONLY ONE) and right next to it is a blact wire(any black will work)
4.) use a peper clip or unisulated wire to bridge the green and black wire by inserting it into the jack contacts.
5.) plug in the power supply, if the fans spins then its working..
If the power supply is fine then you will need to check the power button connectors *wire from power button that connects to the main board),, if the connection is fine, then unjack the connectors and use a bladed screwdriver to bridge the pins for the power button connector on the main board,it should boot up. If not then you need to have that mainboard replaced
Jul 27, 2008 | EliteGroup P4M800-M7 Motherboard
Toys Logo
22 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
