Question about Epson Stylus C84 InkJet Printer
Horizontal Color alignment will not align
I have put in all new color cartridges and run the nozzle check and head cleaning procedures.  Black aligns properly both horizontal and vertical.  The vertical color blocks all aligned except for one which would not change even after numerous realignments.  The horizontal color shows a green line through the blue blocks.  All seven blocks are just alike, there is no variation at all, even after several realignments.  I have shut off the printer for 15 to 20 minutes and tried to realign the horizontal color, but the results are the same.
Any help or suggestions would be appreciated
(btw - I use the printer daily and have had it for about a year and a half.)
    Scholar:
  • 79 Answers
Green color means that there is contanimation from the blue and yellow inks. Try to look inside the printer to where the printhead rests when not in use and see if there is alot of ink there. There may be green ink on the sponge there that may be attaching itself to the bottom of the printhead.
Hope this helps!
Posted on May 01, 2008
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
I have a hp psc 950 I set uo align cartridge clear cartridges, then Itha receive a report saying that align cartridge failed.. Bob
There are several possibilities that you can check. First, what is the ink level for all colors? You need enough ink in all of the cartridges, black and the three color tanks in the color cartridge. A low ink in any one cartridge could do this.
Second, make sure you are printing on clean white letter or A4 paper (no additional print on the page). Is the paper feeding correctly from the paper tray? Did the alignment page print and arrive in the output tray? Check for a paper mismatch warning or if 4x6 paper selector lever is pushed forward on the output tray. Make sure the selector is pushed all the way towards the printer. Did the alignment page look like the previous alignment pages or the ones shown here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=60259#Alignment_Pages .
If any color is missing, look for a problem with the cartridges. Try running a cleaning cycle: press Menu (or Setup, depending on the printer) on the printer. Press the right arrow until you see Maintenance or Tools. Press OK and then OK again if Clean Print Cartridges is highlighted. (Otherwise, highlight the Clean Print Cartridge by pressing the arrow keys and then press OK.) If the output is missing, faded, or streaked. Note: a low ink issue will be made worse with a cleaning. It is a cartridge issue. This could be a symptom of clogged nozzles on the cartridge, the protective tape still on the cartridge, or poor contact between the cartridge electrical contacts and the matching ones on the print head. Remanufactured and refilled cartridges are at higher risk of failing. However, the chip on the cartridge can also fail; in this case, if you have a genuine HP cartridge, contact HP. Replace the cartridges. You may want to clean the cartridges and the print head. Use distilled or bottled water and lint free paper or swabs. (coffee filters can be used.) Wipe away from the nozzles (the contacts, edges and ramps of the cartridge) of the cartridge and the contacts inside the printer. Wipe in one direction only even on the contacts inside the printer.
Reset the printer by unplugging the power cord for at least 5 seconds before plugging it back in. Print a new alignment page. Does the printer give one or two pages? If you only get one page, the alignment is automatic and you should see a blue light at times as the printer feeds and prints the page. If no light shows up, the printer needs service.
If you get two pages, check the scanner glass and white scan backing. Clean the surfaces with a soft cloth dampened with clean water, if they need cleaning. Check if the bulb assembly is lighting up when the unit is on. If that scanner light doesn't come on, the all-in-one needs service. Make sure to put the alignment page face down on the glass or face up in the ADF. Copy the alignment page. If the copy has vertical streaks, clean the scanner assembly. (If this cleaning doesn't help, again the unit needs service.)
You can bypass the required alignment. Press and hold the Enter button and then press the Setup button. The unit should print but the print quality will be poorer. If any colors are missing, check the ink level and for clogged nozzles.
I hope this helps.
Oct 28, 2010 | HP PSC 950 All-In-One InkJet Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Am getting error message of 'alignment failed'. black cartridge will not print
You can run into a problem aligning print heads on almost any HP All-in-One. Fortunately, the problem is usually with the paper or cartridges, not the printer itself.
The quick and dirty fix is to skip the alignment. With the HP printer, you can do that by holding the Enter button down and pressing Setup.
When you're ready to tackle the alignment issue, check the paper first. If there's anything written or printed on the page, if it's any color but white, or if its brightness level—which should be on the package—isn't at least 85, you can't use it for alignment.
If the problem isn't the paper, it's almost certainly the cartridges, which could be low on ink (if you replaced only one cartridge), defective, suffering from clogged nozzles, or past their shelf life.cartridges include a use-by date on the box. The dates tend to be conservative, but if the deadline is long since past, the cartridge could be all but useless.
Run the cartridge-cleaning routine, and then try aligning the cartridges again. If the problem was with clogged nozzles, the cleaning routine might fix it. If it doesn't, the next step is to try cleaning the cartridges and the contacts in the printer. Once you've cleaned the cartridges, try the alignment routine again. If it still fails, and you feel rich enough, you might want to try a new set of cartridges. Or, you might want to bypass the alignment again and use up the ink in the current cartridges first.
Jan 12, 2010 | HP Officejet 7210 All-In-One InkJet...
Photos print with a faint 'pinstripe' effect
that could be head alignment (most noticible on low quality settings .. there is a procedure for aligning the heads ... or it could be clogged nozzles
to check these things start to print something
then select preferences .. then maintainence then
you have a choice .. nozzle check should be done first .. if all nozzles are working then go to "head alignment" and follow instructions there .. if some nozzles are not working then run the "cleaning" utility . sometimes it needs to do that several times .. if you cant get all nozzles working then you can try "deep cleaning" that uses lots of ink so you dont want to do that often ... if that doesnt work then you need new heads .. the heads in many pixma printers are easily replacable but costly ..
if all the nozzles are working and head alignment was done but you still have faint lines then try "high quality mode" .. in that mode you should not see any lines ..
Dec 23, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer says alignment problem, prints only part of black color
first remove the color cartrige and clean the nozzles of the printer and cartridge and run the alignement utilty.
Jan 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Epson Stylus C84 InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
