I want to bypass the k-9 filter and go to any site i want
Washer stopped working in the middle of the cycle, did not drain completely and now will not finish cycle
http://www.partselect.com/Repair/Washer/Will-Not-Start
Sears PartsDirect
the Sears Pars Direct YouTube Videos are at the link above.
Water Filters Lawn Garden Appliance Parts
For questions or assistance, call
1-800-252-1698
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
Great Site and great help.
Jun 06, 2015 | Kenmore Washing Machines
Tip
Do it yourself Mitsubishi PIP module BYPASS
This applies to most Direct view and some projection sets made in the 1990's.
While it is possible to repair in some cases this problem it is quicker and cheaper just to bypass the module--you will no longer have the PIP function.
Here are the bypass instructions:
1.) With the set unplugged remove the back cover and locate the PIP board to the left side of the set--one wire (usually green) is soldered to the metal shield. Unsolder the lead and set it aside.
2.) The board is plugged in and you will have to release the two tabs at the bottom to pull it out.
3.) Locate the pins on the large plug (should be 12 pin) on the bottom of the board.
4.) You need to CUT the copper foil traces with an Exacto knife on pins 5, 7, 9. and 11 near the plug so they are no longer connected to the plug.
5.) You install (on the bottom of the board) a 4.7 mfd filter cap with the + on pin 7 and the - or negative on pin 9.
6.) You install (on the bottom of the board) a 4.7 mfd filter cap with the + on pin 5 and the - (negative) on pin 11.
7.) Reinstall the PIP board and make sure the caps do not touch anything near that board; solder the ground wire back to the shield.
The reason the board fails is because the surface mounted caps dry out and or leak onto the circuit board---there are a lot of them.
SD Tech
I have seen shops replace some of the caps and get it to work but sooner or later more go bad so usually it is better just to bypass the board and not have the PIP feature anymore.
on Feb 12, 2010 | Televison & Video
Tip
How to bypass a MITSUBISHI PIP MODULE
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MITSUBISHI PIP BY PASS
It is possible to repair most of these but damage from the leaking capacitors can sometimes make this tricky or impossible-
Remove back cover and locate pip board to the left of the set--one wire (usually green) is soldered to the metal shield.
The board is plugged in and you have to release the tabs at the bottom to get it out.
Locate the pins on the large plug (should be 12 pin plug)
You need to cut the copper foil traces with an exacto knife on pins 5, 7, 9 and 11. They need to be free of the board.
You install a 4.7 mfd filter cap to + on to pin on 7 and negative lead on 9.
You install a 4.7 mfd filter cap to + on pin 5 and negative to pin 11.
It should only take a few minutes to do this. You will have to remove the board from the set. I have done this a lot of times--Mitsubishi gets 30 dollars for their instructions to do this and no longer sells the board.
The reason the board fails is all the tiny surface mounted filter caps start leaking and fail.
SD TECH
Saab stop running and now wont start
crank sensor . ? di pack ?
May 20, 2013 | 1999 Saab 9-3
I tryed everything all proxys and translate sites but it still won't work i can't pass blocked sites its blocked with lightspeed systems
Go to the FastPassProxy website. FastPassProxy is a free proxy site that allows users to browse the Internet and bypass any firewall, filter or proxy block while preserving anonymity and security.
Enter the URL for the Web page that is being filtered by Lightspeed Systems into the field in the middle of the Fast Pass Proxy website, next to where it says "Site Url."
Click the tab that says "Go" on the right of the field, and you will be redirected to the website that the Lightspeed Systems software was filtering.
There are several other proxy websites that work to by pass lightspeed systems. You can find instructions on how to by pass it by clicking on the link below:
Read more: How to Bypass Light Speed Systems Internet Filter ' eHow.com http://www.ehow.com/how_6873491_bypass-speed-systems-internet-filter.html#ixzz1OcKAM9fD
Jun 07, 2011 | Computers & Internet
How do i bypass verification characters when sending mail thru yahoo
You need somekind of bot to do this for you. The code is called "CAPTCHA" and has been bypassed or broke with a pass rate of 90% which means 9 out of 10 bots will bypass this code.
I don't use Yahoo! so i'm not that up in the breaking codes of Yahoo! department so please click on the link below for a full depth explanation of what to do and how to do it with links to other sites >>>
http://www.messengeroo.com/yahoo-messenger/security/break-yahoo-captcha-by-pass-verification-image-visual-code/
Regards.
Jul 20, 2010 | Dell Computers & Internet
How to unblock facebook
Facebook is a social networking web site that let you keep contacting and dating with friends, share videos photos and music. But it is very bad that if Facebook is blocked, UnblockF can help you unblock Facebook easily, offers free anonymous proxy browsing unblocker bypass service. You also can use the web bypasser to unblock myspace bebo and other social networks.
Click below image to browse
Jul 19, 2010 | Facebook Social Network
Water filter on refrigerator not working. Samsung
This link will take you to the Samsung support site. There you can find the instructions for replacing the filter....if the filter is not properly aligned, the water bypasses the filter
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
Google site problem in Network
check in your firewall security settings.
that blook gmail .
Nov 29, 2008 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
