Question about HP Compaq d530c PC Desktop
530cmt l would like to install another hdd in it's slot and have it as the master how to wire?
  • jueles Mar 04, 2008
    thanks iZen l did see the jumpers for cs ma & sl . So with the ide it would be mother board then slave then master ok. Great thank you.
I have two sata drives install with windows 7 after I install the second drive the PC beeps once at boot up, and I am told to back up, because one of the drives has a problem. I can see booth drives in my Computer, the E drive has a partition and is bigger than the C drive. Can any one help Please.
Posted on May 12, 2011
  • 28 Answers
Before you go to switch any drive to master, look over you optical drives and other hard drives to make sure they are not set on Cable Select with the jumpers on the back of them. If you have 2 optical drives, set one to master and one to slave, same with you hard drives. If you only have one optical drive then set it to master. The jumper layouts are on the big label stuck to the top of the drive.
After setting the jumpers on them you need to install them. Both IDE cables you have 3 plugs. One connects to the mother board, another to the slave and another to the master. Connect them to their corresponding drives.
Posted on Feb 22, 2008
Toshiba 451c "can not find HDD data" message
Had the same problem and solved inserting and extracting the card a whole bunch of times and blowing hard inside the slot. You can also try using the rubber to clean the contacts of the SD. God luck.
Nov 22, 2013 | Toshiba Office Equipment & Supplies
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Laptop 2nd HDD(Slave) running max 20mb/s
Why not install a new 2.5" hdd in your laptop caddy.I replaced my 40gb with a 160gb, works fine and the data tranfer speed is better than a slave configuration. The average speed of around 40mb/sec Is because of the smaller platter, the amount of cache, the firmware installed and so on.
Apr 09, 2010 | Fujitsu Computers & Internet
Sabrent USB 2.0 5-Port PCI problem - ''Pri Master HDD Error''
If you already haven´t installed the driver, I would recommend downloading it from http://www.sabrent.com/drivers/UF6.zip and only then, after a successful install, connect the hardware.
Mar 30, 2010 | Computers & Internet
How do i install an additional sata hard drive on my emachines ET1331G-03W computer?
1.open up the PC, insert the HDD into a free HDD slot, clip/screw it in.
2. plug in data and power cables for new HDD
3. set main HDD jumper to master
4. set new HDD jumper to slave (middle pins)
NOTE: make sure you wear a grounded wrist strap
Feb 08, 2010 | E-Machines eMachines Desktop PC
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
I cant install any operating system in a desktop Gateway
you cannot install an operating system on an hdd on one system and just plug it in to another computer, as windows installs itself according to the specs of the machine you install it to. Have you tried plugging it in to a the second IDE slot? also check your jumper make sure that it is set to master
Apr 30, 2009 | Computers & Internet
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
I installed an additional hard drive in my laptop. The computer will no longer boot up. I've read the the BIOS needs to be changed by I don't know how.
Please tell me which Motherboard your system has???
If you have added an additional drive, check whether you have set the jumpers right for master/slave/cable select configuration.
If you bios setup to boot up from first HDD, then the bootable HDD shall be in master mode. Configure bootable HDD as master & additional one as slave.
If still no luck, Put this additional HDD on other IDE slot.
Tell me if this works...
Jun 21, 2008 | Computers & Internet
Re: lg tower xp install
the boot device setup in the bios, if you set atapi-cd rom as first boot device. then hdd second. and fdd last.
it appears that you have a faulty connection from the IDE ( 40-80 wire cable ) that runs from the motherboard Primary/secondary slot. check the cable goes from motherboard to hard-drive and is connected firmly, also check the jumper blocks ( small white plastic block ) is set to master or slave on both devices ( cd-hard-drive ) if both on same cable set hard-drive to slave and CD rom to master. if they are both set as master or slave, they will conflict with each other.
if you need further help, please mail back.
mike @ compurepair.
Mar 29, 2008 | Computers & Internet
HP Compaq d530c PC Desktop Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
