Question about Whirlpool Dryers
Upon clicking the start button on the Dryer...the motor hums and does not turn the drum. After several attempts trying to engage motor from the start button...it then just clicks. Prior to this the dryer would start and run for about 10 minutes then the motor would hum louder until it would shut off and then not start reverting to the problem explained above...when the dryer did run for that initial few minutes, it did heat up. I have removed the back panels and don't see an easy access to the motor to see if there is a reset switch or if there maybe something hanging up from keeping it engaging the drum and overloading the motor...model LGR4634E
    President:
  • 1,218 Answers
Good day,
Sounds like a bad motor. You access the motor from the front.
You can check bearings while you have it down. The only touchy part is getting the blower wheel off. Sometimes the are frozen, and have to be broken out.
Here's an excellent tutorial.
http://www.applianceaid.com/wpmotor-change.html
Posted on Feb 07, 2010
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dryer motor hums but does not turn when start button is pushed
Jan 24, 2011 | Maytag MDG6000 Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
Jan 23, 2011 | GE Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Will not start consistently. Will make humming
This is a very hazardous condition and you should not use the dryer until it is repaired. First, unplug the dryer! Then, remove the front panel screws (if any), and gently pry it off of the cabinet, door and all. The panel is usually retained by steel clips. Next, check for foreign objects that may be causing the drum to bind. Whether you find anything or not, slide the drive belt to the rear and lift out the drum. Notice how the drive belt is routed through the motor drive pulley and belt tensioner.
Inspect the motor, drum suspension rollers, and belt tensioner for any binding or discoloration. However, if the motor was throwing sparks, replace it. Check wiring harness and connectors and repair or replace if damaged.
If any drum suspension rollers or the tensioner pulley binds, replace them. They're relatively cheap. Upon reassembly, make sure the drive belt is routed correctly around the tensioner before reinstalling the drum, being careful not to twist the belt. Upon reinstalling the front panel, turn drum by hand at least two revolutions -- it should turn smoothly. Plug it in and test the operation.
Jul 09, 2009 | Dryers
Start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
Thanks
Vic
May 15, 2009 | Dryers
Dryers Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
