Question about Westinghouse TX-42F430S Television
Tv has sound but no picture
I have a Westinghouse TV model # TX-42F450S and I am not getting a picture, only sound.
  • 4 more comments
  • meagan1430 Feb 07, 2010
    Hi Sai,
    Thanks for your response. We do not have a glow and can not see anything with the flashlight either.
    No, we do not see anything. Usually the big white "W" comes on before anything and this does not even come up.
    No, we did not see the big white "w" that we usually see either
    No i do not
    Thanks for everything, my zip is 17320.
    I also believe that this TV is under warranty.
  • 4,889 Answers
The picture but no sound on LCDs is usually due to
1)Faulty Inverter board/Backlight
2)Faulty Video driver board also called T-con or timing control board
Turn on the tv and darken the room. See if you can notice a dull glow on the screen. If there is then the inverter board is functional and you have a faulty t-con board
If you don't see any glow then then take a flashlight and flash it on the screen and see if you notice a faint image. Keep flipping the channels to make it more noticeable.
Let me know your findings,
Sai.
Posted on Feb 07, 2010
  • 2 more comments
  • eagle338
    eagle338 Feb 07, 2010
    Do you see a split second flash on the display as soon as you turn on the tv?
  • eagle338
    Ok.. This is where it gets complicated. As the fault can be in one or more of the four boards.
    1)Main Video board
    2)T-Con board
    3)Backlight inverter board
    4)Power board
    Do you have any prior experience in fixing electronics? Soldering, Using a meter(If required) etc.,
    Sai.
  • eagle338
    Then I think it is probably better for you to get it checked by a tv tech. I sure do not want to take a shot in the dark by telling you that replacing some board would resolve the issue even though I think its probably the inverter and t-con board that need to be replaced(Both of them usually cost under 150$ together). However I do think a component level repair might be possible if its the main video board or the powerboard as its usually failed caps that cause this problem. Please provide me your zip code so that I can guide you to a local repair tech.
    Sai.
  • eagle338
    Westing house has a warranty of 2 years(without purchasing the extended warranty) on most of their products. If your tv is under two years old then you are most likely to get it fixed for free. Anyways here is the listing from our repair directory just in case
    http://www.fixya.com/Services.aspx?zip=1...
    Sai.
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Have sound on westinghouse 42 in tv but no picture..just vertical thin lines..thia happened suddenly have hd box rebooted cable. tv will not turn off or on but has power
check it against another computer if the same result then its faulty
is your graphics card a standalone if so that could be the problem
but i am assuming it built in then option 1
Sep 18, 2014 | Westinghouse Tx-42f430s 42" LCD HDTV...
Tv has no picture only sound
the inverter is the usual cause of that issue, some westinghouse models have the inverter combined with the power board. You can get the replacement board and free tech assistance from www.tvrepairworld.com
May 16, 2012 | Westinghouse Electric Televison & Video
Sound with no picture for my westinghouse flat screen tv 42 ' model tx-42f810g
check your video section. the whole board section can be repalce it has on a ic that go bad all the time.i dont have the part number.goodluck
Feb 21, 2010 | Televison & Video
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
No picture from dvd when using hdmi cable
make sure tv is on correct source for that hdmi input.
Jan 27, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
No picture on Westinghouse TX-52F480S.
Hello, I will need a bit more information to help you out on this one. I can troubleshoot with you live on this one just simply email me your contact information to westytech@wde.com or send me an email and I will give you my contact info.
Nov 21, 2009 | Westinghouse TX-52F480S 52 in. LCD TV
Westinghouse tx-42f430s won't power on
More likely it's because of power circuit of your TV set. If you are not trained enough in repairing TV sets, appeal to your local repair center
Jan 25, 2009 | Westinghouse TX-42F430S Television
Televison & Video Logo
152 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
