Question about Garmin nuvi 255W GPS Receiver
How do you change the battery in a Garmin Nuvi 255W?
    President:
  • 1,738 Answers
First, here is the Owner's Manual Rev. A, Sep, 2008 How do you change the battery in a Garmin Nuvi - arrowblack1.gif Download
The battery is non-user replaceable. (See page 34 of the manual)
Posted on Feb 07, 2010
Can't unlock maps on garmin nuvi 255w after update
You can try to power down for hard reset(disconnect battery) and after connect again or reset to factory setting.
Mar 19, 2013 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
Garmin Nuvi 255w
This link shows how to open the case to replace the battery, for example.
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+255W&Show=ExtInfo
It also shows the tool required to open the case.
Hope it helps, please let me know.
Thanks
Apr 27, 2010 | Garmin nuvi 255W GPS Receiver
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Jan 19, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin 255W WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Favorites Backup here.
Will not turn off and wears down the battery
To correct the abnormal behavior of your Garmin Nuvi 255W, I recommend a hard reset and an update of your Nuvi 255W firmware.
I hope that helps.
Jan 10, 2010 | Garmin nuvi 255W GPS Receiver
Open the case of a Garmin nuvi 255w
i am wondering why you want to open it.
There are some small parts that will fall out unless you are very careful and even more difficult to put back when you try and close it up
. Other than to change the battery there are no fuses or user repairable parts inside.
Aug 14, 2009 | Garmin nuvi 255W GPS Receiver
Tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
259 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
