Question about Grilling
My propane ank is full, but when I turn it on high, the flame is barely lit. When I change it from high to low and back to high, the flame level never changes.
    President:
  • 512 Answers
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Posted on Feb 08, 2010
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
Low flame - even at full power. Help! Propane tank is full.
there is a high flow check valve in the regulator designed to prevent large amounts of propane from escaping. sometimes this gets activated by turning it on with the burner valves open. 1. turn tank valve off 2. open burners .3. close burners after 10 secs. 4open tank valve slowly.
Sep 17, 2011 | Grilling
I just bought a brand new kenmore elite grill (for $199). I am new to grilling. The burners seem low - the one on the far left in the back has a flame but all other flame levels are low. Also, I cannot...
If the burners are set to the high setting and the flames are still very low, you may have a bad propane tank. The valves on the tanks go bad sometimes. Take the tank back to where you bought it and tell them you think the valve is bad. They should exchange it for free assuming it still feels full. This has happened to me before, i thought there was something wrong with the grill and it was just a bad tank.
Jun 06, 2011 | Kenmore Grilling
I have a full propane tank. I bbq'd about 3 weeks ago, same full bottle. Grill will not light. Good spark at ignitor. Used lighter and lit for a few seconds with low flame on high. No other burners will...
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Jun 13, 2010 | Brinkmann Charmglow Stainless Steel LP...
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Low gas flow - low heat
Hi Lyon,
Yeah, it's the regulator. Fortunately, they're cheap and easy to replace!
You can look on line for part number 80012. Or you can remove yours and take it to Home Depot or Lowe's in the outdoor cooking area and match up a replacement. <--- they're all the same... just make sure the compression fitting (the brass end) is the same size.
The only other thing I could recommend is this... Turn the LP bottle completely off. Then completely remove the big plastic knurled knob from the tank. Now replace the knob back onto the tank (all the way and make sure it's tight). Then S L O W L Y turn the gas back on. Now try your pit. If you get the same flame, it's the regulator. If you get full flame, you just reset the safety device inside the tank.
I'm betting regulator. Good luck and happy cookin'!
SG
Jun 03, 2009 | Weber Q Grill
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Grilling Logo
296 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
