GPS Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I selected wrong language. How do I reset it back to English
J. Van
Level 3:
President:
  • Master 1,738 Answers
  • Posted on Feb 07, 2010
J. Van
Master
Level 3:
President:
Answers
1738
Questions
Helped
624200
Points
5775
You failed to include the model number of your unit. However, here is a link to the Garmin Nuvi 205. (Click here and see page 35 of the manual for language instructions as it may be the same)
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
If you need additional assistance, just send me a note in the 'comments box' below and include your model number.
If this helped, please rate my answer with a big thumbs-up. Thanks!
1helpful
Netflix choices coming up in Spanish. How do I get it back to English? On the Language section, English is checked.
How to Change the Language in Netflix
Go to Netflix.com.
Select Manage Profiles.
Select the user profile that has the wrong language.
Select your preferred language from the drop-down menu.
Sign out and sign back in to save your new settings
Jan 14, 2019 • Netflix
I've got a Samsung AU55M7000 smart TV with unfamiliar language (set up wrong). How can I reset it to English to understand options
IF YOU HAVE A REMOTE SELECT [ OPEN PROGRAM ] LOOK AT YOU'R SCREEN SCRO UP OR DOWN TILL YOU FIND [LANGUAGE] PRESS [ LANGUAGE ] SCRO UP OR DOWN TILL YOU SEE [ENGLISH] PRESS [ ENGLISH ] AND YOUR DONE..
Want to choose english language
Select settings, on the apps page, scroll down to language etc. and hit, select the language you want, presumably English, then try the phone. or tablet. The machine will now be in English. If you then reset it will probably go back to the language in which you got the phone so do not do it!
1helpful
Set wrong language
On the P90, press the MENU button, select the wrench icon, then select the waving flag icon.
1helpful
My printer was purchased and is used in Germany. The on-screen instructions/options (eg, back to back print,etc) come up in German. Can I change that to english?.
Please follow the steps below to reset the Language on your Lexmark X3350 printer:
  1. Power off the printer.
  2. Hold down the power and + buttons simultaneously for five seconds. This will clear the language setting.
  3. The first prompt you will see is English. If this is not the language required, toggle the + and - buttons to navigate to your preferred language.
  4. Press the arrow button to select that language. The printer will save the new language setting.
Source: Wrong Language on the LCD Display of the Lexmark X3350
How do i change language? accidently hit wrong button when starting camera
Press the Menu button. Select Setup (the wrench icon, or else the last item). Select Language (either the waving flag icon, or else "xxx/Language" where xxx is Language in whatever language is currently selected. No matter the language, it should still say "Language" in English after the slash. In that menu, each language is labeled in that language, so you should see "English" as one of the options. Select that, and everything should be back in English.
1helpful
Its in wrong language
How do u change the language back to english
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
If this does not work.
Reset your iPod—Depending on how much you've used your iPod since selecting the language, simply resetting your iPod may cause it to forget the current language setting, enabling you to select a new one. See "How to Reset iPod" for instructions.
  • Connected. Eject before disconnecting
  • Sync in Progress. Please wait...
  • Do not disconnect
Note: When you reset your iPod, all your music and data files are saved, though you may need to reset some customized settings.
2helpful
How to get my language back to english
Select your language.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Wrong language selected
I actually found the tools icon. And got the language switched back to English. So I did solve it myself. It just took some time. Kay
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
