Question about Canon PIXMA iP4300 InkJet Photo Printer
Cannot duplex print pdf files. No problem for over 2 years until now. Word docs OK have tried changing printing settings and default but problem persists. Advice would be really appreciated. Thanks
Printing PDF files without special software can be a problem, if you print a lot of files of different formats and need to deal with a few printers.
Total PDF Printer from Coolutils is a program features a lot of printing modes and adjustable parameters that will help to optimize the process of printing PDF files. To save the paper, it offers ability to print PDF files in duplex mode, i.e. print PDF pages from both sides of paper sheet.
You do not need to turn each sheet by your hands, as the program changes printer settings so that this process is automated.
Total PDF Printer is a perfect suit for personal or professional use for printing PDF files. It automatically connects to all printers enabled in the system and redirects printing tasks to the trays you specify.
Print PDF Files In Duplex Vertical
Cannot duplex print pdf files. No problem for over - 1f9f0453-6559-4412-a3d6-fb6d2e9f02e2.png
Posted on Oct 14, 2014
5 Suggested Answers
SOURCE: It doesn't print some pdf files from our computer
you can try to use the postscript driver, it should proccess it better. If you need to use pcl driver change the driver setup... under the properites of the driver click port tab... click config port....click lpr and in the Queue name type...print
this should help if not you may need the service tech. to upgrade software rp
Posted on Mar 22, 2008
  • 3 Answers
SOURCE: Unable to print PDF files
use the PS driver for that
Posted on Feb 24, 2009
SOURCE: Canon MP620 Wireless All-In-One can't print to it
Hi
I had exactly the same problem. Here is how I solved it.
I deleted all the previously installed items (although this might not actually be necessary). Then I re-installed using the 'Easy Instal' option from the CD.
The CRUCIAL part is this: - after you have tested your connection to the printer - and it is all fine - another box should appear with a MAC address for the Scan Twain. Highlight the string of numbers and click APPLY.
THEN THE MOST IMPORTANT BIT - look at page 54 in the set-up guide. And follow the instructions which are:
When the printer utility opens click ADD - then go to 'more printers' select the MP620 with the string of numbers after it. This is the one you want NOT the one that appears automatically when you complete the installation.
make this printer your default and away you go! That should work as it has for me and i have been pulling my hair out on this for about 3 weeks!
Posted on Mar 02, 2009
seanpwright
  • 2030 Answers
SOURCE: Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Posted on Sep 11, 2009
How to change paper size from computer & not have to physically go to printer
when you are printing something get to the print area and before pressing the print button click on printer properties and then select the paper size from the list available
save then press the print button
it is only good for the job you are printing as the next job , it will revert to the default setting
Apr 14, 2017 | Canon ImageRunner 1025IF Copier with DOC...
HP Photosmart C7200. Printer is not printing the bottom quarter of the page, despite print preview showing the whole page fits within the margins. I am using A4 paper
Try reseting the printer to factory defaults- also does the same problem happen when you a printing from a computer or trying to print a scan directly on the printer?
try restoring the printer to factory default settings, you can also try reinstalling the drivers on your computer.
Aug 05, 2008 | Televison & Video
Duplex Error When Trying to Print PDF
I found that one of the papers i was trying to print was set for double sided printing, well i don't have the duplex part of it. So I kept getting the error. You have to cancel all the print jobs thru the buttons on the printer. Doing it in your computer did not help and turning off the printer did not help me. So after I cancelled all docs from printing and turned off double sided printing it was fixed.
Jan 30, 2012 | Konica Minolta magicolor 2300DL Laser...
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | HP LaserJet P4015N Printer
I have a Lanier LD335c here at work. I need to store a file on the Document Server. The doc I need to store is a 2-sided paper, and I need it to automatically print as a 2-sided paper when it is selected....
Make all your settings on the copier side as if you were going to copy it. Set the duplex for 2 to 2 as I am assuming your original is 2 sided and any other settings you need. Then select the document server button, set your document name (if you want to change it from the copier default) then press the print button to scan it in. Pretty simple but if I understand your question correctly this should do it. The trick is you need to select the duplex/color/ etc settings before you go to the document server screen.
Good Luck
Feb 25, 2010 | Office Equipment & Supplies
Duplex still has problems printing double sided.
Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
Sep 18, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Aug 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
HP OFFICEJET PRO K5400 - COMMISSIONED FRIDAY OCTOBER 17 1) TODAY OCT 21 PRINTING PDF DOCS TEXT WITH COLOUR PICS, PRINTED SEVERAL COPIES OK, PRINTER STOPPED PRINTING THE PICTURES. AFTER SEVERAL ATTEMPTS...
Try this !
in the software application you are printing from
Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
Look for a Best Mode Setting
this printer has several modes one being draft mode, another one best mode
in best mode the printer uses memory to render the photo you are trying to print.
Note that in this mode, printing takes
longer and more memory is required from your computer.
from page 17 of the hp k5400 user manual
Also you may have to increase the virtual memory of the windows pc to allow the computers hard drive to allocate more hard drive memory to the memory swap file if the computer's ram is not enough to print the photo.
It is a setting in the control panel under system - performance.
May 12, 2017 | HP Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
352 people viewed this question
old marine
old marine
