Question about Panasonic Televison & Video
Panasonic TH-42PV80PA turn off - I do not know why. Now it is only blinking red eye ten times - pause - ten times - pause. Non react on pilot
  • 2920 Answers
SOURCE: Panasonic PZ Th 700U plasma
power transformer is out
Posted on Nov 16, 2008
djchillsnyc
  • 151 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
Yazz226
  • 497 Answers
SOURCE: screen flashes and power light blinks 8 times
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
Thanks for using Fixya
Posted on May 05, 2009
  • 1779 Answers
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Posted on May 23, 2009
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
I plug in my TH-42PZ80U and it doesnt turn on but a red light blinks ten times.
Apparently this common problem is due to a faulty power board. Contact Panasonic for a replacement if it's under warranty (hopefully) or a local repair shop. Good luck!
Jun 06, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
My panasonic plasma tv has some error! the red led bliks 7 times then pause and then 7 blinks again. what i can do? panasonic th-42pz70e
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Sep 12, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
