Question about Philips Magnavox DVD/VCR Dual Player
I think my Magnavox DVD/VCR is dead. How can I
I think my Magnavox DVD/VCR is dead. How can I remove CD from unit.
  • 909 Answers
Remove the small screws from the sides, back and bottom. Take the top cover off by sliding to the back and tilting up slightly. You should then see the disc drawer with the disc in and some cogs to one side. You can manually wind the cogs with a small screw driver to open the drawer.
Posted on Feb 07, 2010
  • Paul Hutchinson Feb 07, 2010
    I should of added that you MUST turn off AND UNPLUG the dvd/vcr
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a magnavox mwd2205 dvd/vcr combo with no remote. I've tried programming it to my Charter cable remote and to a GE universal remote, but can't get it to do anything but turn the machine on and off....
This DVD/VCR isn't compatible with the GE Universal remote. Sorry.
I would recommend contacting Magnavox (actually FUNAI CORP.) at www. magnavox.com, and seeing if they would be willing to send you a remote that was compatible with your player. There was another Magnavox player remote that also worked with Magnavox MWD2205. So it's possible that a number of remotes would work for you. Good luck! :)
Dec 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox VCR/CD player will not come on. It is
I have purchased a new VCR/CD player. I tried everything, but nothing worked. I did purchase another Magnavox, but if this machine does not perform any longer than the first one, I will not purchase another one. The reason I purchased a Magnavox this time was that there were no other products available in my town.
Aug 26, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
No power
1. Check that the AC outlet is working.
2. Check that the AC power cord is ok with no damage.
3. Unplug the unit, remove the cover and check for a blown fuse.
If blown, replace with a value that is the EXACT value as the original.
4. If the fuse blows again or the unit is still dead, you most likely have a problem in the power supply section.
In that case, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Mar 19, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
Jan 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
