Question about Electronics - Others
Have a stereo switch that i need to wire xxxx x xxxx x
  • 30 Answers
OK. I suggest you take a course if you're not experienced. You may need a souldering iron.
I am not responsible for any damage.
-K.R.
"I know what I know because I know what to do!"
Posted on Feb 07, 2010
I need stereo wiring diagram for chrysler 300 srt8
2005 Chrysler 300 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Gray/Light Green
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Green
Aug 31, 2012 | Cars & Trucks
Need wiring diagram for 06 corolla stereo
2006 Toyota Corolla Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: White/Black
Car Stereo Antenna Trigger Wire: Black
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 13, 2012 | Cars & Trucks
2000 Chevrolet Cavalier radio wiring
Here is the color code. Will that do or do you need more?
2000 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: Pink
Left Front Speaker Positive Wire (+): Tan
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 20, 2010 | 2000 Chevrolet Cavalier
Car audio wiring diagram
Here is the color code. Is that what you need, or do you actually need the wiring diagram?
2005 Chevrolet Monte Carlo Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Left Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Dark Blue
Oct 15, 2010 | 2005 Chevrolet Monte Carlo
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
What does wep64 key mean and what do i need to do fot the xbox 360 live connection
WEP Wired equivalent privacy is supposed to give the same security as a wired network in a wireless network. 64 means a 64 bit key is required to get the thing working. Look on the bottom of your wireless adaptor for the key it will be in the format xxxx xxxx xxxx xxxx. type it in carefully when requested.
Feb 08, 2010 | Microsoft Wireless Network Adapter Xbox...
How do you setup the IP address on a toshiba tec b sx4t printer?
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions
{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
Sep 30, 2009 | Toshiba TEC B SX4T Printer
I need a audio wiring diagram
here are the wire colors and what they do, that is all I have.
May 02, 2009 | 2000 Chevrolet Cavalier
When i try to play a and b speakers it says low impedence ??????
I just saw in the title that you're getting a Low Impedance indicator on the receiver...
Following what I said earlier, when you have multiple sets of speakers selected they connect in parallel, effectively presenting a lower impedance than either pair does alone. If your receiver is warning you of Low Impedance you could
A) Ignore it if it doesn't have any audible effects; or
B) Avoid the issue by not running the speakers together or
C) If you must have them running together, wire them in series with each other to present a higher load to the amp and connect each pair of series speakers to the A or B terminals. It would look like this...
spkr A spkr B
XXXX XXXX
L ++++++++XXXX++++++++XXXX
L --------------- XXXX--------------- XXXX
XXXX XXXX
XXXX XXXX
R ++++++++XXXX++++++++XXXX
R --------------- XXXX--------------- XXXX
XXXX XXXX
Apr 02, 2009 | Technics SA-DX950 Receiver
I need to have a date/time received stamp for incoming faxes
Okay Jill, here it is:
Press the 'User Tools' key.
Use the right/left arrows until '2. Fax Features' is displayed.
Press the 'OK' key.
Press right/left until '4. Key Op. Tools' is displayed
Press 'OK'
Press '2222'
Press 'OK'
Press right/left until '7. User Parameters' is displayed
Press 'OK'
'1. Change' should be displayed - Press 'OK'
Now 'Refer Op. Manual: Switch 00 :xxxx xxxx' should be displayed; use the right/left arrow until 'Switch 02 :xxxx xxxx' is displayed (xxxx being a bunch of 1's and 0's).
When 'Switch 02' is displayed, the third digit from the RIGHT should be a 0. Press the '2' key, and that digit should change to a 1.
Press the 'OK'' key.
You should be back at the 'User Parameters' menu - just press the 'User Tools' key to return to the standby display.
Presto, try it out!
Please rate if this helps :)
Mar 05, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Electronics - Others Logo
35 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
