Question about HP LaserJet 1100 Printer
Single sheet paper on my HP LJet 1100a works fine
Printing on single sheets of paper on my HP LaserJet 1100a works fine. Envelopes or index cards slip and jam. Can i replace the rollers or rubber on the rollers myself? i think they've dried out.
  • 28 Answers
There is a recall fix on this printer if it has specific feed problems like pulling in multiple sheets etc. Might be related. You can contact HP and they'll send you a DIY fix kit to replace the rubber that pulls the sheet in and onto the rollers.
Posted on Feb 27, 2010
Won't print envelopes
Envelopes may have to be fed individually through the single sheet feeder
Your word processing software may not have the correct parameters set for printing..
Jan 09, 2014 | HP Officejet Pro 8600 Premium
What is the maximum paper weight allowable for the HP LaserJet 2840 printer? I am printing recipe cards but 4x6 or 3x5 cards are too heavy and the printer won't take them.
Handle a variety of business needs. Spend less time loading
paper with an input capacity of up to 375 sheets. A 125-sheet
multipurpose tray and a 250-sheet paper tray offer easy
access to a variety of paper finishes, sizes, and types,
including labels and envelopes, at weights of up to 47 lb
(177 g/m2) and HP laser glossy and photo papers up to 70 lb
(220 g/m2).1
Jun 08, 2010 | HP LaserJet 2840 All-In-One Printer
When printing envelopes the printer suddenly prints fact sheet
have you updated the firmware on your printer? hp has a firmware update utility down load for it that just might help you with your problem. iu fixed a simular problem by using the download
Jun 03, 2010 | HP LaserJet 1320 Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
HP Laserjet 1300 is printing many pages on one sheet
Sir,
Try to re-adjust the cartridge or reinstall the catridge it will solved
Thanks Good Luck
Jul 21, 2009 | HP LaserJet 1300 Printer
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Scanner will not multi feed takes several sheets
compatible DVD decoder is not installed on my computer. how could i install it ???
Feb 15, 2009 | HP LaserJet 1100a Printer
Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Nov 21, 2008 | HP LaserJet 3380 All-In-One Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Jan 16, 2008 | HP LaserJet 5L Printer
HP LaserJet 1100 Printer Logo
290 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
