Question about Canon PIXMA MX310 All-In-One Printer
Need step by step instructions on how to use the fax on my canon mx310 all in one printer.
SOURCE: canon mx310 fax noise
Ok, I think I have found a solution.
I have read all the posts on the net and with no success I decided to go againts the grain.
After I set all data to default:
Set printer to "Fax priority mode" and set Ring count up to enough that you have time to pick up.
It rings the amount of rings you set it to and then makes a beep sound in the caller's side. It then continues to ring on the printer and asks you to press stop if you want to use handset.
I am still testing this.
Posted on May 28, 2008
SOURCE: Can't fax from Canon Pixma MX310
I spoke to BT, they sugest to put filters on anything which you vconnect, i know that it doesnt make any sense but they said that once youve got broadband connected to your line, all you connect next has to have a separate filters. try it out as i dnt c any other methods. It worked for him by the way!
Posted on Nov 23, 2008
  • 13433 Answers
SOURCE: i lost my cd to install canon mx310 printer to my computer
Hey,
you can get it from here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Click on drivers and downloads
then select your windows version and download the files
install the printer
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
Posted on Mar 11, 2009
efs_perpends
  • 1996 Answers
SOURCE: Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Posted on Apr 10, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
I lost my instructions to hook up my printer to my computer i have a canon mx310.. i need to know which phone cord goes into the computer and printer?????
I hope this installation/setup guide will help you [Click Here]. If I am right, you don't need a phone cord to connect the printer and the computer, but a USB cable. If it's in case of Fax, you would need the phone cord to connect the line to the printer/fax machine.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
Jan 23, 2011 | Canon PIXMA MX310 All-In-One Printer
Need to fax, have no instructions, need step by step process.
First of all, What is your home phone service.. If you have a VOID service. Like Vonage - then make sure that your service has been fine tuned for fax usage.
Step by step..
Your MX310 must be plugged in to a Active phone line.
(1) Start by placing your fax materials on the top scan bed feeder. text, picture side facing upwards.
(2) There are 3 choices on your control panel, Choose Fax and the Fax button will then be lit.
(3) Enter in the fax number that you wish to send to.. And hit the Start button on the control panel.
Black or in Color.
As long as you have an active phone line and compliant phone service - you should be good..
Thank you for your visit to FIXya.com
Dec 08, 2010 | Canon PIXMA MX310 All-In-One Printer
I dont know how to send faxes woth my canon mx310. Where do i put the phone line in the spot that says L or under the picture of the phone?
You need to use your PC to send/receive faxes. You cannot directly use your printer to send/receive faxes. I dont know what operating system (e.g. Win7, Vista, Mac) you're using. But if it's windows, you can find instructions on how to set it up by clicking on the link below.
http://tinyurl.com/2b37whh
Hope this helps.
Oct 24, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i send a fax with my cannon MX310 what are the steps?
Plug a phone line into the LINE port place original face up on the feeder dial the fax number press START (fax)
Jun 16, 2009 | Canon PIXMA MX310 All-In-One Printer
I need help setting up the fax option on my Canon Pixma mx310
maybe you've done a mistake of installing the driver of the printer...try to uninstall and reinstall the driver of the printer...and set up the fax .
i hope it help
May 13, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax doesnt work
Go to control panel and open the printer. For faxing, make sure you have selected "Series FAX" and not the actual Printer.
This might be the problem
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310
Did you connected the line at "L" slot or try with your phone operator to check your tel. lines
Jul 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
