HELP ERROR MESSAGE
Hello I have a compaq armada 100s I'm getting an error message that says x_rabcosc.exe DLL intilization failed windows station is shutting down. i get this message when the computer is trying to boot up. is there something i can do???? please help
  • Cece2768 Feb 22, 2008
    Hey D, any other suggestions? I'm just stuck!!
    hey d thank you for the info i ran it in safe mode and was able to download spybot but i can't run the program from safe mode. and my computer won't stay up long enough to run it.
    Scholar:
  • 121 Answers
Yes, boot up into safe mode and then wait.. shut it down and reboot up regularly and see if that helps.. did you recently install any new software or devices? it may be spyware so if it is and you can get it to boot up long enough, download spybot and run it to remove any spyware you may have.. it's a free download so is adaware.. let me know if this helps.. d
Posted on Feb 22, 2008
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Jun 07, 2009 | Office Equipment & Supplies
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Cd drive not starting up
There is no setting required that you have to set. The cd should be seen automatically. If possible test the cd drive on another laptop or get a second cd drive to check on you laptop.
Could you rate this if helpful.
Thanks
May 04, 2009 | Compaq Armada 100S Notebook
Trojan - antivirus-xp-pro-2009
Take my notes as a guide and hopefully this will work for you.
1. Start > Run > msconfig > “Start Up” tab > Disable All
2. “Services” tab > Check box “Hide Microsoft Services” > Disable All
2.5 Exit out, but don't reboot yet
3. Start > Right-click “My Computer” > “Properties” > “System Restore” > Check box “Turn off restore on Hard disks”
4. Start > Run > type %temp% > Edit Select All > Shift-Delete
Reboot machine
1. Combofix.exe. This program will run on its own. Also, it will likely wish to reboot the machine. Let it complete.
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
2. WinSockFix.exe. This will fix any issues with the network connection.
3. SuperAntispyware.exe. This will remove all remaining spyware, tracking cookies, and browser hijackers.
Check to see that your favorite internet browser is working. Install or re-enable your favorite antivirus that failed to catch this in the first place.
Stop WinAntiVirus2008 Processes:
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Remove WinAntiVirus2008 Registry Values:
2178F3FB-2560-458f-BDEE-631E2FE0DFE4
6F520BE0-9B54-4558-816F-224E67997DF3
459F4226-1AAB-43B6-9DC1-B6313EF83749
1AC5C88A-DEA7-462b-A232-04AF5CA42E7E
723D54C7-7483-4EB8-8EED-CE5B2AEA534D
Find and Delete these WinAntiVirus2008 Files:
WinAntiVirus Pro
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WinAntiVirus Pro.lnk
Reinstall or Uninstall WinAntiVirus Pro.lnk
WinAntiVirus Pro Manual.lnk
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Vista
Stop WinAntivirus2008 Processes:
(Learn how to do this)
WinAntivirus2008.exe
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Find and Delete these WinAntivirus2008 Files:
%UserProfile%\Desktop\Viruses.bdt
%UserProfile%\Desktop\WinAntivirus2008.lnk
c:\Program Files\WinAntivirus2008
c:\Program Files\WinAntivirus2008\Viruses.bdt
c:\Program Files\WinAntivirus2008\VRM2008.exe
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008\WinAntivirus2008.lnk
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\WinAntivirus2008.lnk
%UserProfile%\Application Data\Mozilla\Firefox\Profiles\s1jqw0bz.default\cookies.sqlite
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Remove WinAntivirus2008 Registry Values:
5222008A-DD62-49c7-A735-7BD18ECC7350
HKEY_CURRENT_USER\Software\WinAntivirus2008
WinAntivirus 2009
# 1. Find and Remove the following Antivirus 2009 Processes:
* av2009.exe
# 2. Find and Remove the following Antivirus 2009 files and folders:
* C:\Program Files\Antivirus 2009
* C:\Program Files\Antivirus 2009\av2009.exe
* c:\WINDOWS\system32\scui.cpl
* c:\WINDOWS\system32\winsrc.dll
# 3. Find and Remove the following Antivirus 2009 files and folders:
* HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\ CurrentVersion\Run\15358943642955870504508370025739
Mar 06, 2009 | Microsoft Windows XP Home Edition Service...
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
May 01, 2008 | Computers & Internet
Compaq A3000 Drivers won't install in Windows XP Home
Ths looks like a not properly removed software. What you can do is to remove the software manually by removing all the files and registry keys. But do this at your own risk. I suggest that you do a backup of your computer first
Nov 24, 2007 | Compaq A3000 All-In-One InkJet Printer
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
