Question about Ricoh Aficio 450 Copier
RIcoh CL 7000 having problem within the copier, it's locked and unable to use WHat should i do
  • David Spicer
    David Spicer May 11, 2010
    Need more details, is the screen on, what does it show, any error messages ect....
  • 62 Answers
Most likely if you have no error code displayed then one of the hard drives is bad.
Posted on Feb 10, 2010
Why can't I pull out the intermedicate transfer unit?
Check the lock and any other will be there.
So open the transfer unit locks and pull ir out.
Mar 07, 2016 | Ricoh Aficio CL-3500N Type 165...
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
My Ricoh 2238c color copier has a SC440-01 error, what can I do?
Main motor error
The main motor starts or changes
speed. The lock signal does not
continue for 1 second within 3
seconds.
• The main motor starts. The lock
signal is detected and operation
proceeds normally. The lock
signal is interrupted for 1 second.
Causes:
• Defective main motor
• Too much load of the main motor drive
Nov 01, 2012 | Ricoh Aficio 2232C Color Copier
I have replaced the fuser unit and fuser oil, and still getting streaks different places on the paper. Ricoh Aficia CL 7000
One or more of the drum units or the transfer belt cleaning blade is bad. Only way to tell is to remove each drum and check the surface for the toner "streaks". You can also pull out the transfer belt and check the surface for the streaks. It will be one or the other. Now if you streaks are of a particular color then that points more to the drum of that color.
Jan 06, 2010 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Apr 17, 2009 | Ricoh Aficio Colour 3006 Color Copier
Dirty copies on Ricoh Aficio CL 7000 copier
Did you replace the fusing oil as well? toner will not fuse well and deteriorate your new fuser very quickly if you are out of oil
Feb 03, 2009 | Ricoh Aficio CL7000 Laser Printer
Installation driver for Ricoh Aficia CL7000 laser printer
go to www.ricoh.com, usa, downloads and then select your printer in the drop down windows, lastly choose your operating system. now just unzip the file and install
Sep 26, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh cl 7000
To my understanding since this model is a print server by itself, should you want to connect it straight to a laptop and not through a hub or router, perhaps you can try using a cross-over cat5 networking cable instead of the regular straight through.
Additionally, the IP adds of the printer and laptop should be near (192.168.15.16/printer and 192.168.15.xx/laptop).
Alternately, the printer will allow also connections by parallel, USB and bluetooth.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 14, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio 450 Copier Logo
108 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
