Question about Kenmore Dryers
The timer is not advancing on my elec. dryer Kenmore 90 Dryer mo. 110.60902990
On me dit que ma cles de 25 chiffres est pas bonne ces celle qui est endessous de mon portable
Posted on Feb 07, 2010
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Hello there:
I would have to tell you that i dont think that the two would fail at the same time but it can happen but not too often
deffinatly replacethe timer and the heating element and this will solve the problem
also since you have the unit opened i would inspect all of the wiring for loose connections and moisture cause this will cause things like these to fail prematuraly ok?
I hope that this has peeb very helpfull for you
best regards michael
Nov 04, 2009 | Kenmore 659 Electric Dryer
Elec. dryer timer won't advance and i'm getting no heat
Yes it can. The moulding near the contacts has probably melted. You can test it by bridging the contacts. If the element gets power, then you can replace the timer.
Sep 09, 2009 | Dryers
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Timer doesn't shut down dryer machine
the timer is easy to change, check how much it is first, mine was around $100.
Apr 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
