Question about Philips 42 in. Plasma TV
Picture comes on for split second
Philips 42' Digital HDTV Compatible Plasma TV 42PF5520D
When i knock it on the picutre comes on for a split second then the screen goes black i can still hear but no pic
  • 30 Answers
Hi.
Are you sure this is not on somthing like hide screen mode?
I am not responsible for any damage.
-K.R.
"I know what I know because I know what to do!"
Posted on Feb 07, 2010
Went to turn on tv from the side button and loud zap noise and bad smell coming out!
you horizontal output transformer inside the unit has a high voltage leak.
if you know how to open the back cover. you can try to clean the dust buildup
inside and in the back of the tube check the unit if still produce bad smell.
if still zapping replace your high voltage transformer it may have a leak.
Aug 26, 2011 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
Hi. I have a 42PF5520D Philips 42" Plasma. Started
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem....
May 06, 2011 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options,...
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
Dec 27, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Wont come on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Mar 21, 2010 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
Picture takes split second to focus
That normal,this tv a year or more right?Mornal progressing the aging of the tv.
Mar 19, 2010 | LG 42PQ30 42 in. Plasma TV
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 42pf5520d faulty
Hi, the power supply board has a little board towards the connectors. This board has an led and it will blink if there is an error, check how many blinks there are and then check on the on the power PCB next to this little board you will see the error explanation. Also check capacitors on the power board next to the control board connector, replace any bulging ones. I hope this helps.
Feb 01, 2010 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Nov 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Philips  42 in. Plasma TV Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
