Im trying to solve a problem with a dryer, not a washer. why is it showing up as washer?
  • 3,741 Answers
You will have to select the dryer category but you have selected the washer category so its showing up washer. but no problem.as you have mentioned its dryer problem but not mentioned what the problem is in your dryer.so it will be hard to answer your dryer question. so i will give you one direct link for all types of dryer troubleshooting. please click on this link directly http://www.applianceaid.com/dryers.html
also for parts please click on this direct link You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 07, 2010
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
As this wd640 is a washer dryer, im sure there must be a filter some where I need to clean etc but dont know how to find it or go about it.... Had a manual but cant find it... thanks Elaine
Hi.
Yes there is a filter.
Remove lower rear panel of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump, check for obstruction or blockage here, and look inside the pump as well.
This should solve your problem.
Nov 30, 2009 | Hotpoint Aquarius WD640 Front Load...
Im getting test coming on display
try this - press start, press start again. Now press the on/off button and the start button at the same time and hold them down for 5-10 seconds until the display shows d-end or d-off.
Oct 31, 2009 | Hotpoint Aquarius WD640 Front Load...
My frigidair FEX831CSO stacked washer/dryer has quit drying. Was wondering where the heating element is
Try to get in the back of the dryer section? If you can, i believe you can get to it from the back im not to sure, its been a while since i work on this model...to help you out better go to this websit www.partselect.com and then type in your model number. click on your model number and it should pull up diagrams. click on the dryer section and it shows where each part is located...hope this helps...
Jul 30, 2009 | Dryers
Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Jan 31, 2009 | Haier HWD1000
Washer dryer works but no heat
Some dryers have a thermal trip which can be reset often from the rear. Other than that, best to check the heating element with a multimeter - this will show you if power is reaching it, and if so, the element is bust. If no power, then it will be a wiring fault or perhaps a problem with the PCB electronics.
Jan 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Wd71 with e30 code on display when i try to use the dryer
try changing the thermostat located on top of heater in top of machine
Nov 08, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint supersilent washing machine
Try pushing the "on" & "start" buttons together for 5 secs or more. If it does not clear from the display, switch of the machine for 5 mins and try again.
It would be nice if you rate me, thanks.
Dec 26, 2007 | Hotpoint Aquarius WD640 Front Load...
Kenmore 417.948.62301 Stacked Washer / Dryer Problem
Pull the knob off the timer and you should see the screws that hold it in place. Access is from behind.
Oct 31, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
