Question about Axial Syma 9086 Helicopter
I need instructions on how to repair main rotor blade with connectors
    Genius:
  • 1,341 Answers
The best thing to do is to replace the blade.The reason being that if you try to glue or somehow manage to get the blade back to one shape then it will cause a misbalancing among the blade as one will be heavier than the other and this won't work as it should.Hope this helps.
Posted on Feb 07, 2010
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Exceed Rc 2.4 Ghz WarHawk 300 RTF Co-Axial Airwolf replacement of main rotor gear. Do I drop motor out of fuselage by removing bottom blades?
In order to get at the main rotor gears, you'll have to remove both sets of rotor blades and drop the chassis. After removing the battery cage you should be able to access the two main gears. You don't need to remove the motors, but if you need to access the main gear for the lower-rotor, further dis-assembly is required. I think there's a link to a dis-assembly video for the Exceed models on rcdiscuss
Sep 20, 2010 | Exceed-RC Toys
Displays LE and will not wash dishes
LE is a motor error.
Possible Causes: Wiring connections, Impeller is locked, Rotor is locked, and or the Blade is locked.
Remedy: Repair the wiring issue, Remove the item stopping the turning of the motor/rotor/blade, Replace the sump assembly, or Replace the main Power Control Board.
If your motor was making in knocking sound before this error, then your issue is probably the motor sump assembly. Just replace the sump assembly and your problem is resolved. You can get these from EBAY for about $105 with free shipping.
Good luck.
Jul 18, 2010 | LG 24" Built-In Dishwasher - Black
Replace tail rudder blade on walkera cb 180d
yea cut it off longways down the shaft with large parrot nose plyers finish with little ones back up shaft and drive on rotor with small deep well socket simple!,
Apr 01, 2010 | Walkera #35C: Main Rotor Blade (Fiber...
Phone is dead, battery fully charged. Need instructions on how to disassemble the phone to look for obvious problems.
From the back of the phone, remove 1 screw @ the top/center. Take the battery cover off, remove the battery. Remove 4 screws. With a medium size blade
screwdriver, gently pry the case apart at the battery charger hole. Just pry the plastic, not the connector case. Then with a very thin precision blade screwdriver, work your way around both sides of the case. Note: there is a connector that goes to the display portion of the phone. Once the case is open, gently pry the connector of the main circuit board. There will be a keyboard cover, 2 side button plastic pieces, 2 side button circuit boards, the top plastic cover, and the bottom main circuit board.
Good Luck
Russ
Jul 13, 2009 | LG VX5400 Cellular Phone
Changing the blades on the Set 735-61 c helicopter
Hi
I have the same problem too what you need to do is to get the replacement parts and try to release the upper rotor blade by twitching it back and forth until it releases. it will take time don't despair, in the end it will be release since they glue it with super glue. afterward release all the other parts remember their order. Thats it you need to have patient try not to bent the main rotor shaft .
Cheers
Ronen
Jan 04, 2009 | Electric 3CH Mini Sport RTF RC Helicopter...
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Axial Syma 9086 Helicopter Logo
94 people viewed this question
Top Axial Toys Experts
thegtw
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you an Axial Toy Expert? Answer questions, earn points and help others
