Question about Whirlpool Freezers
Have got a Whirlpool 20RU-D3J with ice maker...... cannot stop this thing making ice, I've been emptying the ice out because it was getting full, but now I forgot to do this and its broke the ice tray... now filling the ice collector with water. Would recommend one of these freezer for a deep sea trawler...plenty of ice for the fish! Many thanks
  • 523 Answers
Change the ice maker
Posted on May 05, 2010
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
I have a side-by-side (MDL: 106.53552202). My ice maker has stopped working... I do get water from the door. The ice container is empty, the switch is turned ON.
there could be a blockage of frozen water in the fill tube of the ice maker.
if there is no blockage then the nex thig to check is the main water valve that supplies the water to the ice maker.
you can check the power from the main pcb board to the ice maker and make sure you have current to the ice maker
if all else fails replace the ice maker
i hope this has helped in some way good luck
Jan 31, 2010 | Freezers
My ice maker wont deliver ice. can you help
Ice maker/ ice dispenser manual HERE
If the ice maker mold is empty try adding some water. Wait. If a batch of ice pops out then water valve replacement is in order. If it fails to pop out a bit of ice then the ice maker is bad. I have more information on a page I created HERE
Jan 18, 2010 | Whirlpool Freezers
My ice maker stop working
Knowing how an ice maker works can greatly increase your ability to diagnose and repair it. Just like vehicles, ice makers all may look different but they all work on the same princible. A thermostat starts the ball rolling, turning on a motor and a heater to loosen the ice, as the ice dumps a trigger fires up the water valve and refills it. The whole thing comes to a halt and waits till the thermostat gets satisfied once again.
So what can go wrong? The ice maker will give a clue. If their is ice in the ice maker but none in the bucket that is an ice maker failure. If the ice mold is empty and no ice in the bucket then the water valve is bad.
One thing you can do is get a bottle of water and fill the mold. If it kicks out a batch but no more, water valve replacement needed. If it don't then ice maker problem. If you have shelling or fouled cubes, look for dirty coils below the ice box that make for faulty cooling. Ice forms at 32f but ice mold tstats don't kick in the afterburners till 25f. I have some more detailed tips with videos and manuals: HERE
Jan 10, 2010 | Freezers
Ice maker will only cycle once then it goes to off position . It stop working due to ice build up in supply tube. I removed the ice maker and ran hot water over unit to clear out the ice that was lodged in...
That bar your talking about goes to the full up position just before the end of the harvest cycle then falls right at the end of the cycle. But on a good day it barely drops. Characteristic of that ice maker.
If you ran water over the ice maker try these 2 things.
1. Remove the ice maker and leave it on the counter for about 2 days to completely dry out. Then re-install and try again.
2. If no luck, hang a small weight to the middle of the wire to see if it will drop on it's own.
3. If no luck, you'll have to replace the ice maker. However,
if your commited to buying a new ice maker, first snap off the front cover and look for interference where the wire goes into the ice maker. You can actually remove the whole solid state front end by removing the 3 screws that hold it on and make a more detailed check.
P.S. pull the wire out of the ice maker before this last step. It simply pulls out.
Oct 28, 2009 | Whirlpool Freezers
We have a Whirlpool K40 Ice Maker but it seems to have stopped producing ice. The motor is running but there is no water coming into the machine & therefore no ice is being frozen & cut by the...
a few things to check, first off is adequate water supply(obviously).. next check your drain system, if your unit gravity drains look for a blockage, but if you have a secondary drain pump to pump away water check for proper operation, if that pump fails the machine will no longer let water in( thinks it full and no need to produce more ice if it cant get rid of old water
Jun 09, 2009 | Whirlpool Freezers
Whirlpool side by side s20erww2v american f/freezer
Is the ice bucket still full? Ice makers have built in mechanism to cut itself off when ice bucket is full.
Sep 12, 2017 | Whirlpool Freezers
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Freezers Logo
183 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
