Question about Whirlpool Duet GHW9150P Front Load Washer
Door Lock does not lock
Whirlpool Duet Model GHW9400PLO. When starting the machine, I hear the door lock clicking but it does not lock. After about 6 attempts, it goes into a DL error.
  • 2 more comments
  • W1FZT Feb 22, 2008
    The clicking noise comes from the top left rear corner of the machine.
  • Anonymous Dec 23, 2008
    We have the same problem. It makes two beeping noises and does not turn on. It will then proceed to make continous beeping noises showing dL and F on the display. Our model is GHW9400PLO
  • zebo0923 Dec 25, 2008
    I am having the same problem and I have been waiting over 2 weeks to get the warranty work done. This machine was purchased in August and was purchased as Lowe's - at this point I am very frustrated with customer service at Lowe's and Whirlpool. They are now telling me it will be another 2 weeks before anyone can get out to fix it.
  • Anonymous Mar 21, 2014
    F11 appears machine will not start although door is locked
    Problem Solver:
  • 19 Answers
Check this website before doing any replacement.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Mar 02, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
Posted on Feb 22, 2008
  • Ron Coons
    Ron Coons Feb 22, 2008
    latch(8182634) is about $60 bucks, that rear board( 8182280)$250, beforereplacing either pop the top look down the front right side and check for wire harness possibly popped of latch assy
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
Whirlpool duet model # ghw 9400 lo.door locking problem.
One hour service plus $40 part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 14, 2010 | Whirlpool GHW9400 Front Load Washer
Whirlpool duet - door will not lock. Was working fine and now when I press start, I get the code "FL"and then "d" flashing.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Jan 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer front load and its giving me a message of dl f. I can hear it trying to click but nothing happens.
This should indicate a door lock error and the clicking is the door trying to lock. The door is supposed to attempt to lock six times before the dl error is displayed. It is most likely caused by a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
GHW9400PLO
The "Fdl" code is a Door Latch Lock error. Inspect the door latch for obstructions that may be preventing it from locking and doublecheck the wire harness to ensure all the connectors are intact. If the latch is defective, use the following link for advice on how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Another method of replacing the latch is to remove the top panel and work form the top down behind the front panel. Due to limited space, this may not be desireable to some.
Replacement latches can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for your search criteria. These sites have great service and offer competitive pricing. Check out all three for the best savings.
I hope this information helps you. Let me know if you need further assistance.
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
392 people viewed this question
Dan Webster
Dan Webster
Sal De
