Question about ViewSonic N3251w 32 in. LCD HDTV
My N3251W has no power on. It was working fine last nite when i went to bed, this morning i turned it on and it has no power. I changed out cables and outlets still no luck.. any suggestions
4 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Viewsonic flat screen tv. That
No there are no fuses in that type of flat screen TV. If it will not power on at all then it sounds like a failed or at least failing power supply inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will want to contact a local TV repair person in your area if you are sure this is out of warranty, more on that in a bit here. This is actually the most common problem with this type of TV, I see it every day, it just happens - sometimes with new TVs and sometimes it takes many years for it to happen.
If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
If you want to attempt the repair yourself please let me know and I will get you the part number and a place you can purchase it from for what you need.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Posted on Nov 03, 2010
budmrtn
  • 11361 Answers
SOURCE: I plug in my ViewSonic
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=viewsonic&megnev2=n3250&kategoria=tv&kat2=all
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Parts: www.shopjimmy.com
Posted on Nov 19, 2010
marmeto12
  • 155 Answers
SOURCE: i purchased viewsonic N3251W. It worked fine for 2
hi;
please check the connectors of power supply board, and reset all connectors.
if you have digital or analog tester,try to read the output voltage of the power supply
http://www.youtube.com/
maybe no +5v going to mainboard..
or check the front panel board if its properly connected to mainboard.
thanks....give some comment so i can help you more....
Posted on Sep 14, 2011
After a huge lightening storm, my tv seems to be frozen, went on this morning but will not chang channels or even turn off. I can't find a reset button Help!
Unplug the set and any peripherals that are plugged into it. Then push in the power button and hold for at least 60 seconds. This should reset it to recover from the surge effects caused by the lightning.
Sep 05, 2010 | Polaroid 1911-TLXB 19 in. LCD TV
Won't turn on
Lots of power supply issues with Viewsonics. Out of warranty? Open up the back and have a look at the power supply if you know something about electronics, otherwise, call a repair shop.
Apr 23, 2010 | ViewSonic N3251w 32 in. LCD HDTV
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Thankyou for your help ive took the back right off and theres 3 lamps red green and white, i bought this samsung 42in rear projection 2nd hand it worked absolutely fine the first nite i got it then...
Cheryl at a guess i would say that was why it was sold. It has an intermittant control board fault.
Now these often extend beyond just the one board ( there are 3) Opening the TV up is a risk to you as not only does it have scatter radiation type X but it is the HIGH TENSION area where severe burns and electrocution is the risk. Call a professional to fix it. We have people on here all the time trying to do this on the cheap, not many suceed as often they think that just swapping the boards out will fix it. Rare! Most times it ends up costing 3 times as much because they dont have the knowledge, essential tools or the skill to tune it properley and they end up fritzing the board again or blowing the expensive lamp.
Thanks for using FIXYA Please rate oure help to keep the FREE service online++++
Sep 18, 2009 | Televison & Video
WORKED FINE WHEN TURNED OFF, THEN NO SOUND WHEN TURNED ON
1. I would first make sure that correct "INPUT" setting is registered.
2. Try a different input source such as VCR, DVD or CD.
3. Connect a pair of audio RCA cable to all the VIZIO set's audio inputs one at a time and touch the center tip while the set is powered ON and the input is set to the corresponding seting. If audio circuit is OK you should hear a hum with at least one of the input settings..
4. If still no audio, then it maybe the audio circuit board needs to be checked.
May 15, 2009 | Vizio L32 32 in. LCD HDTV
TV will not come on.
check to see if the power cord is pluged in firmly
Dec 17, 2008 | Sylvania 6427GFG 27" TV
Light Status on Netgear WGR614
Access router. What does it say? did you set up the wireless network yourself? Is the cable modem working properly? Rebooted it? Is there a problem with the internet provider?
Dec 14, 2008 | NetGear WGR614 Router
Linksys wrt54gs won't work
Your router might need a restart to begin communicating with the modem again. Remove power from the router, wait a few seconds, then turn the power back on.
Nov 22, 2008 | Linksys Wireless-G WRT54GS Router...
Vizio vp50
Maybe the scart has gone or it is not in properly hope this helps..
Jan 22, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
ViewSonic N3251w 32 in. LCD HDTV Logo
29 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
