Ihave a whirlpool electric dryer that just stopped working. i was told there is a fuse i need to change. can you tell me which fuse and where it is located?
    Brigadier General:
  • 3,917 Answers
Dryers have a thermal fuse, which burns out when the dryer overheats; in that case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
It is suggested to replace a hi-limit thermostat when replacing a thermal fuse.
Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 07, 2010
  • 11,896 Answers
If you look in the back inside of the machine where the plugin is. There is the power supply/high-voltage transformer. THis provides power to the unit. Next to it should be a fuse. Either a ceramic or a glass bus type fuse. There should be a thin wire inside of the fuse. The wires can break and then the fuse is no longer any good.
  • Nate Stansfield
    Nate Stansfield Feb 07, 2010
    You can view all the parts, pics, part numbers and more at partselect.com
  • Church Hill Dec 02, 2010
    This response should be ignored, it is completely inaccurate.
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
Whirpool dryer stops after 30 seconds of operations, i replaced the fuse as was told by the online expert, but it still does not work,
Check that the filter isn't blocked. This is probably located on the back wall of the drum.
Ensure the vent isnt obstructed, blocked or kinked.
Feb 28, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool duet not heating, replaced thermistor
If it just won't heat, it's a thermostat issue (most likely). You can try a different setting and check if it works. There are different thermostats for different settings. Also there is a contact that is operated by the motor to insure that the drum is turning for heat.
Jul 01, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer Help
Hi theres 2 things that can cause this #1 a dirty vent to the outside. #2 a dirty lint filer , Take the lint filter out & run hot water through it. If water wont flow through the screen, Its gummed up by Bounce sheet residue, Clean the filter . It should be ok
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Dryer
My dryer did the same thing, all the lights worked on front, but the bulb was out inside. All I had to do was to replace the thermal fuse and replace the bulb if you want light. The bulb don't have to work in order to dry clothes
Jan 03, 2008 | Whirlpool GEW9250 Electric Dryer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
