Question about Garmin nuvi 885T GPS Receiver
New nuvi turned on when I inserted battery; but only with Garmin logo - can't shut it off, just comes back on even if you hold on/off button "off" for several seconds.
    President:
  • 1,738 Answers
You may want to contact Garmin Customer Support
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Posted on Feb 08, 2010
My garmin 265w doesn't start it just turns onto the garmin logo and that is a half screen
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Sep 26, 2011 | Garmin nuvi 265 Car GPS Receiver
Tried shutting it off. It won't shut off or anything else. Has a picture of the Garmin logo on the screen as well as a picture of a computer. It's a Garmin Nuvi 1450
Hi, A soft reset will preserve your Home, Favorites, POis, etc.or just remove the battery. Leave the battery in the unit. Hold down on the lower right of the screen while holding down on the power button. After 20-30 seconds, you should see the Garmin splash screen. Have your PC/laptop ready with USB cable. Get the latest Map update downloaded and installed or just start using the unit again. i hope this will be very helpfull to you. please don't don't forget to vote me Good Luck
Jan 22, 2011 | Garmin nuvi 1450 GPS Receiver
My garmin 1350T just shut off and will not turn back on
If your garmin nuvi shuts off and refuses to turn back on, even if you press the power button, then it means the battery is weak and cannot power on the nuvi. Try to take out the battery and reinsert it back it then try to turn it on to see if it will turn on, if it does not still turn on, then borrow a battery from a friend and use it to test your nuvi, if it powers on, then your battery is either weak or dead.
Insert the battery into another gps and charge it with another charger for about 2 hours to see if it will hold a charge, try to use it to power your nuvi on to see if it will work. If it works, then it means your charger was not charging it initially. That means the charger is bad and need to be replaced, but if the battery does not turn on your nuvi after charging it for about 2 hours, then it means the battery is bad and need to be replaced.
Either ways both the charger and the battery need to be checked to know which of the two is faulty.
Carrying out the test will show you the faulty component and the solution is for you to replace it with a new one.
Hope this was helped you.
Dec 24, 2010 | Garmin nuvi 1350 Car GPS Receiver
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
Oct 16, 2010 | Garmin nuvi 1200 Car GPS Receiver
Nuvi 775 GPS Receiver: My Garmin nuvi 775 will come on with the Garmin lo...
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 03, 2010 | GPS
Just got it yesterday...worked fine and now it won't start up, only flashes on and off, I did shut it off by holding the on button on
I can help you reset and fix your Garmin Nuvi 265WT.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Mar 13, 2010 | Garmin nuvi 265WT Car GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi
I had this same problem.  Just lift up the antenna on the back, hold the reset button for 3 seconds, and then plug it in to an external power source.  Mine started right back up after just going black one day while driving and not turning back on until i did this.
Aug 19, 2008 | Garmin nuvi 350 GPS Receiver
Brand New Garmin nuvi 350 Shut Off, Won't Come Back On
Sounds like a very dead battery, have you charged it with the wall socket yet? Are you sure the car charger works?
Jun 21, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 885T GPS Receiver Logo
99 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
