Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Washer will not tumble
My washer is filling water the timer comes on the wash signal light comes on the time is running and the washer will not tumble
Operator error LOL.
Posted on Feb 18, 2010
Washer ills with water with sensing light on but does not switch to wash cycle
The timer gets it's information from the fill sensor, so it it doesn't start and you are sure the fill sensor is signaling the timer correctly, then I would look for a timer problem. Try advancing the timer a little after filling and see if it takes off.
Feb 01, 2017 | Kenmore Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    My washer is tumbling damped clothes but seems not to be acutally washing my clothes. whats going on? Just a bit water comes out for about 2 sec then stops but no water is actually in the drum just...
    This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
    Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
    Good luck,
    John C
    Apr 09, 2011 | Kenmore Front Load Washer
    Water runs but doesn't fill tub and wont spin if put on spin cycl
    The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
    Jan 09, 2010 | GE WBSE2090A Top Load Washer
    Washer doesn't work and the water doesn't come on.
    Check the water valves work, fill then wash, then drain then spin, if it doesn't fill it won't wash
    Nov 12, 2009 | Maytag LSE7806A Top Load Stacked...
    GE Dishwasher won't fill (Tested valve and switches)
    check thermostat it maybe overheat and gives a false signal that water is warm,it is on bottom.
    Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
    Washing machine fills in the water but does not start the wash cycle
    The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
    See from Repairclinic:
    "This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
    However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
    A possibilty is that either the timer is faulty or there is a problem with the water supply.
    Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
    More likely you will have to replace the timer.
    See again from Repairclinic:
    "When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Frigidaire Tumble Action Washer
    I called in an electrician/plumber - thanks !
    Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
    70 series Kenmore washer
    POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
    IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
    Mar 31, 2008 | Kenmore 22422 Top Load Washer
    Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
    199 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
